![]() | Home > Maintenance & Modifications > Heated Washer Jets |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
How good are these at motorway speed ??
consumerize Member Since: 27 May 2014 Location: Berkshire Posts: 121 ![]() ![]() ![]() |
Work fine at 70. Hits the screen only 3 or 4 inches lower than when stationary
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
Heated jets now completed, adjusted and working great.
![]() Thanks again Consumerize, worthwhile mod. On the old 90, I have two washer pumps on the reservoir and since I don't use the rear (second) one, I've rewired it to work in tandem with the front one. Loads of water now - and hitting the windscreen in the right place. What a difference. Not quite the same position as yours but just as effective. See photo below... hopefully! ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Defender 90 Toyota Aygo & Honda FR-V Last edited by LRmud on 6th Feb 2015 12:28am. Edited 1 time in total |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
I've done the cheap option:
�4.80 - 5 metres of 4mm tube.. Marginally warmer output.. I'm sure it will help in -15 temps but overall, not any worthy noticeable difference. ![]() |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Away back when I had my Series 3 I seem to remember one of the mags did a small feature with details of how to fit a coil of copper pipe around the exhaust to heat your washer water, been trying to find the write up without success
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315 ![]() ![]() ![]() |
Spotted this on eBay, anyone got one?
![]() ![]() http://www.ebay.co.uk/itm/271953843490?_tr...EBIDX%3AIT http://texautomotive.com/classic_accessories.html Sandy |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
Old thread I know, but you can get the heat shot now for £49 on ebay
http://www.ebay.co.uk/itm/HEATSHOT-HEATED-...SwcRNZqBK5 ![]() |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1334 ![]() ![]() ![]() |
I could have done with some form of heated washer jets on the way home from work today.
Nozzles frozen up despite a fairly concentrated mix of washer fluid in the reservoir. Lots of salt water mist from the road, but not enough to dampen the screen to the point where the wipers could clear the screen. So I ended up peering through a greyed out windscreen on the motorway. Like driving in thick fog. In the end at the earliest opportunity, I threw half a bottle of diet coke on the screen whilst in a traffic queue ![]() I dread to think what that will have done to the windscreen frame and brackets!!! I'm sure the flat glass plays a big part in building up muck on the windscreen. Do you think these heater devices will be effective without heated nozzles? Or will the nozzles freeze anyway, thus preventing the hot water from flowing through? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
I can't see any reason to suppose that any device that heats the fluid would stop the jet from freezing. I think what is needed is an electrically heated jet, which many vehicles now have.
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Up to press I’ve not had any issues using pure screen wash
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2319 ![]() ![]() ![]() |
I'm using the low temp stuff neat which seems to be doing the trick and not freezing.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I've had one of those on my mini for years. It's pretty effective to be honest, good a shifting bugs in the summer too. But as said above using decent winter or all season screen wash (which contains antifreeze) works fine. The initial heated jets at the beginning of the post may well be used on the Range Rover Sport , but they're the same as the MK3 Mondeo ones. On most cars they're simply powered all the time the ignition is on. |
Land Rover Defender Expedition Camper Heated Screenwash Washer Jet Heater System
On eBay New one for sale at a very reduced price! Sandy |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
