Home > Maintenance & Modifications > Anybody got a Stainless fixings list |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
That’s a very very long list.
I’ve gone down that road for the last 4 years. Changing everything to stainless. I’ve used duralac. And i can highly recommand that. After 4 years still no corrosion between stainless and non stainless. I’am sorry i haven’t kept records. I normally Just take 1 out and order those Kind regards Jacco a defender from 1984 pretending to be a puma with a touch of Range Rover |
24th Feb 2018 11:13am |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 578 |
Exactly what I’m trying to avoid. Short of taking stuff off in the car park at the supplier I’d be stuck with undoing everything twice. Once to measure and once to replace
24th Feb 2018 11:27am |
Luckily its not that bad.
Most of the Times you can undo a bolt. Ie third row Seat and then order them for all the Seats. Anyway that’s how i’ve done it so far But if you don’t want to do that you can look it up in microcat. a defender from 1984 pretending to be a puma with a touch of Range Rover |
24th Feb 2018 11:53am |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Perhaps Martin could make some sort of sticky thread where people can add bolt and nut sizes as they come across them, it might not help original poster but would develop into a usefull tool ...... A list of torque settings would not hurt either.
Anybody with some free time could use this website www.landroverworkshop.com to start the list from the diagrams. when sourcing ss fasteners you need to be aware that there are a lot of Chinese poor quality ss fasteners out there...cheapest is not always the best way to go.........sometimes vendors have done some of the work for you and I for one don't mind helping to improve their retirement fund by paying a little extra....as long as they are not taking the Micky! |
24th Feb 2018 12:40pm |
That’s a great idea.
I feel an excel sheet coming. Also include which grade of ss (A2/A4) and strenght (70/80) Greetings a defender from 1984 pretending to be a puma with a touch of Range Rover |
24th Feb 2018 1:28pm |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 |
This site looks pretty good https://www.landroverworkshop.com/diagrams/body-chassis/doors.
I bought my 110 new in 2009 just had the steel wheels powder coated this week and I had been wondering about replacing the bolts around door hinges. Thanks |
24th Feb 2018 6:39pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1070 |
For the doors see below.
Problem with 1st and 2nd row doors is the shape of the heads ('raised countersunk'? is that the correct term?). Only supplier I know of is nakatanenga. all: TX 40, M8 1st row upper and lower hinges: M8x40 (A-Post) M8x55 (door) 2nd row upper: M8x85 (B-post) M8x55 (door) 2nd row lower: M8x95 (B-post) M8x55 (door) rear door all three hinges: M8x25 (body) M8x50 (door) |
24th Feb 2018 11:26pm |
Thanks macfrank that's a good start.
25th Feb 2018 7:12am |
Thanks
A trip to the supplier next week it is then. |
25th Feb 2018 10:16am |
That is the way I was thinking there is a supplier in my area but may not have these in stock, but they can order them for me.
25th Feb 2018 11:08am |
If you source them croft......can you post the cost?....including post!
25th Feb 2018 12:01pm |
No problem I will post costs etc.
25th Feb 2018 1:05pm |
Not been to my local supplier but found Paddock have this.
http://www.paddockspares.com/bolt-kit-1.html |
27th Feb 2018 10:25am |
27th Feb 2018 11:02am |
