Home > Puma (Tdci) > Engine cutting out. 2.4 Tdci 2007
sjwdrew
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Help!
My 110 xs sw is cutting out! Fine will cruising but then when I come to slow traffic or a roundabout the engine cuts out, no warning lights on the dash come up. Turn the key and it starts fine and drives fine then in the same scenario it does it again!
In the garage at the moment and nothing coming up on diagnostic. They have taken it out and it's been fine Big Cry Thought it might be the earth so they are checking the electrics. Could also be the fuel rail release valve? But they are reluctant to just pop one on as it costs £100+ Shocked
Anyone out there with ideas?
Simon
Post #688212 22nd Feb 2018 2:03pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Have they had a look a Fuel rail pressures?
You can get cheaper aftermarket FP sensors for around £25. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #688225 22nd Feb 2018 3:10pm
sjwdrew
Would that not show on a diagnostic tho?
Post #688228 22nd Feb 2018 3:23pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
My best tip.
Go and drive with a nano com (or something similar).
I had the same end result as you had. In limp mode and no errors. In the end it was an overheating issue, it could only been seen with a nano com. The meter in the dash was stille in the middle Shocked but the water temp was 110 C?????
Good luck a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #688229 22nd Feb 2018 3:23pm
ian series 1
Yes It should do?
But then not everything is as straight forward as it seems!
You can still get problems, and no codes. Rolling Eyes
Is it actually cutting out, or going to limp mode? 80" 80" 86" 88" 90"
Post #688231 22nd Feb 2018 3:26pm
sjwdrew
Oh Joy Laughing
Well I'll let them get back to my re the electrics and take it from there........ Big Cry
Post #688232 22nd Feb 2018 3:30pm
Tdi4
Oh definitely yes.
Had it twice already (different problems, no error code but same result: limp mode). Therefore i've bought the icarsoft to monitor the parameters whilst driving.
Greetings, and I mean this: good luck with finding the problem a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #688237 22nd Feb 2018 4:15pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Hi
I have had this problem on 2 different occasions, on the first time I replaced the valve at the end of the injection rail, but this made it better but it was not until we did an injector and pump reset & learn that it solved it but only for a year or so and it came back.
I found that if I disconnected the MAF sensor the problem stopped, it then ran on a default settings, cleaning the MAF sensor improved the problem but did not remove it completely. Replacing the MAF cured it.
The problem was like yours, no fault code the engine would just cut out when pulling up at traffic lights or roundabouts, or not respond to the accelerator pedal, switching off and restarting it would run OK again.
It was not until I replaced the MAF sensor that I realized the engine had been running so poorly. I was able to monitor the MAF sensor output on the IDtool I have and the output would jump all over the place, with the new sensor it almost stable at constant speeds.
If you replace it, you must do and injector learn and pump reset.
Hope this helps. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #688240 22nd Feb 2018 4:58pm
sjwdrew
Ian series 1, it’s completely cutting out.
Post #688354 23rd Feb 2018 7:10am
sjwdrew
Cable to the battery mega-fuse was loose! Rolling Eyes
At least that's what they think at the moment, going to do some more test runs in it.
Post #688428 23rd Feb 2018 1:51pm
Martienssen
Hi sjwdrew, I'm having the same issue, did you ever get to the bottom of it? It's a 2007 too.
Post #718332 18th Jul 2018 9:18am
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Honestly, to me it sounds like the VCV valve. Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #718418 18th Jul 2018 6:36pm
sjwdrew
Hello Martienssen,
I thought it was going to be the VCV as well and the garage was standing by to replace, however they decided to check all the electrics first and low and behold turned out to be a loose wire between the battery and the mega fuse!! Since this I have had no problems (touching lots of wood!!!)
Good luck.
Simon
Post #718475 18th Jul 2018 9:26pm
Griffon12
Similar issue on my 2008 2.4, which I've narrowed down to the fuel rail. I can get a good price on the assy with both the VCV and the regulator new and attached. I'm confused about whether I'll need to have the pump re-learn or not. Haynes doesn't suggest it for the full rail replacement but it seems to be mentioned frequently for the VCV replacement. Would appreciate any clarity before I jump in.
Cheers, all!
Post #719444 24th Jul 2018 2:16pm
Caterham
while there check the battery lead / clamps are secure onto the battery (ie don't just assume that they are secure because the bolt to tighten them is tight). good luck.
Post #719445 24th Jul 2018 2:26pm
