Home > Maintenance & Modifications > Load liners / sound proofing and fitting |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Looking at the genuine LR rubber load liner for my td5 SW or perhaps the Exmoor trim load liner with sound proofing built in. Just wondering your opinions as I could just get some carpet underlay and put the genuine mat on top.
Also is it best to remove the bench seats to fit or cut grooves etc? https://www.exmoortrim.co.uk/our-models/de...25-73.html |
14th Jan 2018 8:12pm |
When I did mine recently, I fitted the sound proofing but cut holes out for the seat fixing:
Click image to enlarge Click image to enlarge I carpeted the entire tub and then put a rubber mat over the top: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Jan 2018 9:21pm |
Nice , did you just buy regular carpet and cut to fit? Did you spray glue it all?
14th Jan 2018 9:55pm |
No, it's a stretchy nylon stuff especially intended for vehicles stuck down with spray glue. There's a bit more detail here:
http://www.defender2.net/forum/post637884.html#637884 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Jan 2018 8:06am |
I'm obviously blind but can't find a link in that thread to the carpet used?
15th Jan 2018 8:14am |
I didn't include a specific link but if you put 'veltrim' or something like 'van carpet' into eBay, you'll find there are lots available. Darren
15th Jan 2018 8:30am |
Found it thanks, how much silent coat did you need btw for the tub?
15th Jan 2018 9:25am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 712 |
There's a genuine LR version that does floor and wheel boxes in one piece but it's not cheap. https://www.famousfour.co.uk/new_parts/ff_part?part=6797
Had one in my old 90, it looked nice but was not very thick, if you are hoofing logs into the back then the wheelboxes will still dent. As cheaper and more sturdy options I'd look at, chequer, buffalo board or stable matting 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
22nd Feb 2018 10:13am |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Cheapest solution would be a few rubber mats used in stables, get the 38mm stuff, its designed for 650kg + horses to walk on, it'll do the job well
22nd Feb 2018 10:46am |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 726 |
Ok
Thanks very much both |
22nd Feb 2018 11:53am |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 234 |
Has anyone done anything that will fix over the stepped arch of a station wagon in rubber as well as the floor space? I want to avoid carpet.
15th Nov 2018 12:47pm |
