Home > Maintenance & Modifications > Load liners / sound proofing and fitting
Djcla
Looking at the genuine LR rubber load liner for my td5 SW or perhaps the Exmoor trim load liner with sound proofing built in. Just wondering your opinions as I could just get some carpet underlay and put the genuine mat on top.
Also is it best to remove the bench seats to fit or cut grooves etc?
https://www.exmoortrim.co.uk/our-models/de...25-73.html
Post #678467 14th Jan 2018 8:12pm
When I did mine recently, I fitted the sound proofing but cut holes out for the seat fixing:
I carpeted the entire tub and then put a rubber mat over the top:
 Darren
Post #678502 14th Jan 2018 9:21pm
Djcla
Nice , did you just buy regular carpet and cut to fit? Did you spray glue it all?
Post #678524 14th Jan 2018 9:55pm
No, it's a stretchy nylon stuff especially intended for vehicles stuck down with spray glue. There's a bit more detail here:
http://www.defender2.net/forum/post637884.html#637884 Darren
Post #678583 15th Jan 2018 8:06am
Djcla
I'm obviously blind but can't find a link in that thread to the carpet used?
Post #678587 15th Jan 2018 8:14am
I didn't include a specific link but if you put 'veltrim' or something like 'van carpet' into eBay, you'll find there are lots available. Darren
Post #678594 15th Jan 2018 8:30am
Djcla
Found it thanks, how much silent coat did you need btw for the tub?
Post #678619 15th Jan 2018 9:25am
arran jones
Hello All,
As everyone knows i have a 90 pick up..
I am looking at getting a rear load mat to protect the floor...
What does anyone recommend..i use it quite a bit for forestry work..so i am looking for a tough thick rubber mat
To keep iy clean and tidy in the back when its full of logs etc Thumbs Up
Is there any that includes the box sides aswell or not??
Mt
Arran
Post #688171 22nd Feb 2018 9:06am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
There's a genuine LR version that does floor and wheel boxes in one piece but it's not cheap. https://www.famousfour.co.uk/new_parts/ff_part?part=6797
Had one in my old 90, it looked nice but was not very thick, if you are hoofing logs into the back then the wheelboxes will still dent. As cheaper and more sturdy options I'd look at, chequer, buffalo board or stable matting Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #688184 22nd Feb 2018 10:13am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Cheapest solution would be a few rubber mats used in stables, get the 38mm stuff, its designed for 650kg + horses to walk on, it'll do the job well
Post #688191 22nd Feb 2018 10:46am
arran jones
Ok
Thanks very much both Thumbs Up
Post #688199 22nd Feb 2018 11:53am
LR Sam
Has anyone done anything that will fix over the stepped arch of a station wagon in rubber as well as the floor space? I want to avoid carpet.
Post #740669 15th Nov 2018 12:47pm
