Home > In Car Electronics > Where have you fitted your switches
Mr.Tom
United Kingdom 1989 Defender 90 200 Tdi HT Alpine White
So on the to do list is tidying up one of the previous owners cabling and random switch collection.
I am thinking of mounting a bunch of carling switches to cover,
.. rear work lights
.. front driving lights
.. light bar
.. interior lights
Leaving space for future expansion to cover a possible winch installation, other lights, etc
So I’ve got a 200tdi, show me where you’ve mounted yours? (Oh err)
I am going keep hazards and fog light in the same location (near the door) but probably upgrade the switches there too to carling switches. It’s currently a random mix of OEM and other
Post #687226 17th Feb 2018 5:49pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Probably the neatest and most OEM looking setup would be the mud centre console: http://www.mudstuff.co.uk/products/mud-stu...nsole.html Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #687233 17th Feb 2018 6:16pm
dioliahary
I have this set up, also with a 200tdi. Consists of rear work lights, front work lights , interior light reverse camera switch and rear seat electric feed.
Post #687238 17th Feb 2018 6:36pm
There are various options available for fitting extra switches to the centre of the dashboard. Have a search for 'center switch panel' on eBay:
 Darren
Post #687240 17th Feb 2018 6:45pm
Mr.Tom
Thanks guys. Quite like the look of the Mud one, plenty of space, option for a CB later.
Might even consider moving the hazards and that over to it too.. all switches in one place!
Post #687244 17th Feb 2018 6:54pm
dioliahary
I moved the hazards over to the centre but then converted back to the original position. 1990 200tdi conversion 90
Post #687245 17th Feb 2018 6:56pm
Mr.Tom
Why didn’t you like them in the new position?
Post #687247 17th Feb 2018 6:59pm
dioliahary
It was mainly due to having to extend the existing loom and I managed to do this but used too thick gauge wiring. So it took up too much space behind the Mud dash and it was too inflexible. My mistake really, may have been better using thinner gauge wiring. 1990 200tdi conversion 90
Post #687249 17th Feb 2018 7:05pm
Mr.Tom
Thumbs Up
Post #687251 17th Feb 2018 7:10pm
ibexman
In the process of fitting
Post #687281 17th Feb 2018 9:24pm
Mr.Tom
Looks good
Has anyone put carling switches in the lower right switch panel where the hazards and dogs are?
I was looking for a mounting plate to use but can only find either OEM fit or an expensive one from the US
Post #687326 18th Feb 2018 7:55am
I don't think that plate is big enough for Carling switches. If you want different types of switches to use there then 'E-Switches' are a direct replacement. You can buy them from lots of places but this gives a good idea:
http://www.mudstuff.co.uk/products/electri...ounts.html
I'd also recommend replacing the plastic plate with an aluminium or stainless one, as the original is prone to crack. Metal replacements are available from eBay for not much money. Darren
Post #687327 18th Feb 2018 8:05am
boode
England 2003 Defender 90 Td5 HT Rutland Red
A couple of calling switches replaced the blank window switches and new switches along the base
Post #687337 18th Feb 2018 8:54am
Mr.Tom
I saw this for the lower panel, https://www.seriesdefender.com/dash-switch-panel-row.html
Only seems to be available in the US though and quite expensive.
I will replace the mounting plastic when I get there (or extend the loom and put everything in the middle)
Post #687340 18th Feb 2018 9:02am
gilarion
I have fitted Bolt on Bits end panel switch
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #687373 18th Feb 2018 2:43pm
