Home > In Car Electronics > Where have you fitted your switches |
Mr.Tom Member Since: 09 Dec 2015 Location: St Neots Posts: 34 |
So on the to do list is tidying up one of the previous owners cabling and random switch collection.
I am thinking of mounting a bunch of carling switches to cover, .. rear work lights .. front driving lights .. light bar .. interior lights Leaving space for future expansion to cover a possible winch installation, other lights, etc So I’ve got a 200tdi, show me where you’ve mounted yours? (Oh err) I am going keep hazards and fog light in the same location (near the door) but probably upgrade the switches there too to carling switches. It’s currently a random mix of OEM and other |
17th Feb 2018 5:49pm |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 507 |
Probably the neatest and most OEM looking setup would be the mud centre console: http://www.mudstuff.co.uk/products/mud-stu...nsole.html Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
17th Feb 2018 6:16pm |
There are various options available for fitting extra switches to the centre of the dashboard. Have a search for 'center switch panel' on eBay:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
17th Feb 2018 6:45pm |
Thanks guys. Quite like the look of the Mud one, plenty of space, option for a CB later.
Might even consider moving the hazards and that over to it too.. all switches in one place! |
17th Feb 2018 6:54pm |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 |
I moved the hazards over to the centre but then converted back to the original position. 1990 200tdi conversion 90
17th Feb 2018 6:56pm |
Why didn’t you like them in the new position?
17th Feb 2018 6:59pm |
It was mainly due to having to extend the existing loom and I managed to do this but used too thick gauge wiring. So it took up too much space behind the Mud dash and it was too inflexible. My mistake really, may have been better using thinner gauge wiring. 1990 200tdi conversion 90
17th Feb 2018 7:05pm |
17th Feb 2018 7:10pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2949 |
In the process of fitting
Click image to enlarge |
17th Feb 2018 9:24pm |
Looks good
Has anyone put carling switches in the lower right switch panel where the hazards and dogs are? I was looking for a mounting plate to use but can only find either OEM fit or an expensive one from the US |
18th Feb 2018 7:55am |
I don't think that plate is big enough for Carling switches. If you want different types of switches to use there then 'E-Switches' are a direct replacement. You can buy them from lots of places but this gives a good idea:
http://www.mudstuff.co.uk/products/electri...ounts.html I'd also recommend replacing the plastic plate with an aluminium or stainless one, as the original is prone to crack. Metal replacements are available from eBay for not much money. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
18th Feb 2018 8:05am |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 434 |
Click image to enlarge A couple of calling switches replaced the blank window switches and new switches along the base |
18th Feb 2018 8:54am |
I saw this for the lower panel, https://www.seriesdefender.com/dash-switch-panel-row.html Only seems to be available in the US though and quite expensive. I will replace the mounting plastic when I get there (or extend the loom and put everything in the middle) |
18th Feb 2018 9:02am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
I have fitted Bolt on Bits end panel switch
Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
18th Feb 2018 2:43pm |
