Home > Maintenance & Modifications > Rear recovery Point
CFB
Rear recovery Point
May seem a silly question but will my 110 CSW have a rear recovery point as standard? Not coming with a tow pack and I am thinking that I may need to order a swivel eye or similar for the rear. Andy
Post #683 14th Nov 2007 11:45am
TJ101
Re: Rear recovery Point
Hi,, In a word NO, never seen a Defender ,with any recovery points as standard, leave the factory California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #685 14th Nov 2007 6:25pm
CFB
OK thought so Sad Andy
Post #686 14th Nov 2007 6:34pm
AndrewS
I will post pictures and contact details of the supplier of the rear recovery the Red Dwarf has installed.
Post #687 14th Nov 2007 10:15pm
CFB
Seen some decent looking recovery eyes at Scorpion racing that bolt into the existing holes on the rear crossmember. About £30 though + P&P which looks steep. Andy
Post #688 14th Nov 2007 10:39pm
NoDo$h
or failing that, Jate rings are £9 each from Rebel4x4 http://www.rebel4x4.co.uk/steering_guards.htm
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #692 15th Nov 2007 8:55pm
CFB
Cheers but I don't like Jate rings on the rear, they are too far under the body to be useful. Andy
Post #695 16th Nov 2007 8:32am
JSG
As someone who would rather not give my cash to Scorpion I'd recommend Famous Four for recovery points as per link below;
http://www.famousfour.co.uk/foursport/shackle.php//url
I also saw an excellent swivel recovery point at Billing - now if only I can remember who sold it??
Post #703 16th Nov 2007 5:26pm
CFB
Scorpion one arrived today, brilliant item, very well made and comes with bolts to fit the pre-threaded inserts in the crossmember. Took about 2 minutes to fit and looks well up to the job. I also bought some stronger bumper corners from them too to protect the rear 1/4 panels. Will post pics once fitted. Andy
Post #743 21st Nov 2007 6:00pm
AndrewS
Rear recovery fitted to the Red Dwarf. The recovery point is removable and an adjustable ball tow hitch can be mounted in its place. Purchased from this place ask for Tom
Post #761 22nd Nov 2007 11:38am
dshickle
2007 Defender 110 Puma 2.4 CSW Galway Green
I've been looking at one of these from where you suggest. (I have some other items from them which are excellent!!)
It looks like a great solution instead of the ground anchor created by the adjustabe tow hitch from LR.
My only concern is the tow hitch is no EU compliant (or whatever they call it). Is it safe?
Does it have any impact on insurance?
David Disovery 3 TDV6 SE
Defender 90 XS 2.4
Defender 110 S D250 (MY22)
Post #775 22nd Nov 2007 8:37pm
AndrewS
Don't know I got it for the rear recovery and it came with the towing kit. I'm sure Tom will answer your questions Thumbs Up
Post #776 22nd Nov 2007 8:59pm
CFB
This is the one I have, less substantial than AndrewS 's but for what I need it will do the job.
 Andy
Post #777 23rd Nov 2007 12:16pm
JSG
Continuing on this subject - my intention was to use a tow bar as a recovery point and I have a Landrover genuine adjustable tow bar ready to bolt on.
As pointed out it does hang down and act as a bit of a plough but then I don't intend too much more than laning in the 110, no winch challenge stuff and it has the benefit of being easily adjustable for different height draw bars.
Looking at the recovery point straight on to the crossmember this is a neat solution but is the crossmember up to recovery without any brackets back to the chassis?
Reason I ask is that the pre-tapped holes in the crossmember will accept a NATO hitch and I happen to have one sitting in the garage which could bolt straight on.
What do you reckon?
Post #1430 21st Feb 2008 2:53pm
AndrewS
Land Rover say that tow points are not recovery points. Personally I would not be happy recovering a vehicle thats got its recovery point fixed to the rear cross member only. They do bend.
Just My Opinion. Thumbs Up
Post #1432 21st Feb 2008 4:51pm
