![]() | Home > Technical > Dash feed to reverse TD5 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17682 ![]() ![]() ![]() |
The connection from the switch to the reversing light does not go anywhere near the dash, it runs from the gearbox over to the right hand chassis rail then down to the rear of the vehicle.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
It's not hard to connect to the reverse light switch under the centre seat. However you need to be aware that it's an earth switch, so you'll need to connect the earths from your scene lights to the reverse switch.
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 177 ![]() ![]() ![]() |
Useful info, thanks chaps. I'll look at how to adjust the wiring to suit a switched earth! 2002 Defender 110 CSW TD5
voorfrank Member Since: 06 Feb 2017 Location: Schiedam Posts: 37 ![]() ![]() ![]() |
It is just in front of the bulkhead on the right hand side
![]() Click image to enlarge ![]() Good Luck. |
