Home > Technical > Dash feed to reverse TD5
steve_c3
United Kingdom 2002 Defender 110 Td5 SW Epsom Green
Hi all, I've done a search but can't find the specific info I need so wonder if one of you guys may have the answer...
I am currently fitting a couple of Scenelites to the rear of my 110 with various switches to operate them. One switch will turn them on when reverse is selected. As such I need to splice into the live feed from the gearbox switch. Does anyone know if there is an easy place to access this feed near the dash?
Thanks in advance,
Steve 2002 Defender 110 CSW TD5
Post #686522 14th Feb 2018 10:22am
The connection from the switch to the reversing light does not go anywhere near the dash, it runs from the gearbox over to the right hand chassis rail then down to the rear of the vehicle.
Post #686523 14th Feb 2018 10:26am
zsd-puma
It's not hard to connect to the reverse light switch under the centre seat. However you need to be aware that it's an earth switch, so you'll need to connect the earths from your scene lights to the reverse switch.
Post #686552 14th Feb 2018 1:03pm
steve_c3
Useful info, thanks chaps. I'll look at how to adjust the wiring to suit a switched earth! 2002 Defender 110 CSW TD5
Post #686563 14th Feb 2018 1:44pm
voorfrank
Netherlands 2002 Defender 110 2.5 TD SW Bonatti Grey
It is just in front of the bulkhead on the right hand side
Good Luck.
Post #686722 15th Feb 2018 10:37am
