Home > Technical > Help please DCPU rear bulkhead stiffner part number.
rodspink
Hi folks.
I have a 110 DCPU which I am rebuilding. I have replaced the rear bulkhead behind the rear seats . Part number ABB710040
On the old panel there is a stifner bar which runs the full length of the panel.
I cannot find it in any parts manual. Even more concerning neither can Land Rover. Wonder if anyone has any info on this part. I would make one but its a relativly complicated shape. A similiar part is fitted to the 90 rear bulkheads too.
Thanks
Rod.
Post #686506 14th Feb 2018 8:47am
rodspink
The bar can be seen in this attached picture running the full length of the panel around half way up.
Thanks
Post #686507 14th Feb 2018 8:50am
bankz5152
Tried YRM?
Post #686515 14th Feb 2018 9:37am
rodspink
Good shout.
I did have a look but never seen any . Although I was going to drop them an email which I will do right now.
Thanks for the reply .
Rod
Post #686517 14th Feb 2018 9:43am
bankz5152
They may have it just listed as something else! I found that when buying a few door repair bits.
Post #686518 14th Feb 2018 9:58am
Does it have to be the correct, genuine stiffener? You could easily get hold of an extruded aluminium angle section and use that if you weren't too fussed about originality.
On a different but related subject, does anyone know why 90s and 110 DCs have the two removable panels in the lower part of this bulkhead (they can clearly be seen in the photo above, below the stiffener)? The look like access panels but I have never figured out what they are there for.
Post #686528 14th Feb 2018 10:50am
Grenadier
^^^ I've wondered the same. I await an answer with interest. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #686548 14th Feb 2018 12:50pm
I've always wondered that. too. Given their position, I wondered if it was something to do with early seat belt anchor points that's just never been deleted. Darren
Post #686568 14th Feb 2018 2:05pm
rodspink
Blackwolf.
Thanks for the reply.
The piece sits right where the bulkhead changes angle. So it is very unique. My goal is keeping as orignal as possible. My last resort would be chequered plate on the outside of the panel to beef it up a bit. The rest of the load space is chequered anyway. Tbh i would prefer not but it would be an option.
As for the holes. No idea either lol
Cheers.
Rod
Post #686572 14th Feb 2018 2:22pm
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
Maybe you are looking for AQU710010?
/Max
Post #686616 14th Feb 2018 7:18pm
mk1collector
Mk1 vw caddys also have two removable plates in a very similar position so I'm guessing for either moving around during assembly or for welding during assembly. Ray
My build thread
Post #686620 14th Feb 2018 7:32pm
/Max
That certainly looks about right.
Post #686624 14th Feb 2018 8:00pm
rodspink
Hi folks.
Yeah I tried that one . Its the bottom support that goes to the floor. Im making them from a piece of angle.
Thanks again.
Rod
Post #686633 14th Feb 2018 8:52pm
