![]() | Home > Technical > 2014 Puma Help - EGR Codes & Wiring |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Can he not open up the loom from the EGR and follow it back?
Looms are notorious for rubbing through in various places. I’ve had similar issues with voltage drop to the EGR, and having an intermittent fault on ABS/TC. Mine was two broken wires in the loom going back to the ECU. If there is a rub through, you will soon see it! ![]() Wanted, Forward Control Anything considered. |
Have a look here - http://www.defender2.net/forum/topic20997.html?highlight=dgardel
