Home > Technical > No ignition lights. Turns over but fails to start.
Relentless
United Kingdom 2010 Defender 110 Puma 2.4 USW Keswick Green
Spent the past few days fitting the Ashcroft transmissions MT82 output shaft upgrade.
Battery has been disconnected the whole time whilst transfer box removed / replaced.
Come to reconnect battery. I have no ignition lights.
Landy turns over when key turned but will not start with no ignition lights.
Handbrake light on, heater fan works, light and indicators work but no ignition.
Checked every fuse.. even the under seat. Nothing found.
Disconnected the earths. Sanded and refitted. Nothing found.
Rechecked all transfer box wiring. Nothing found.
At a loss now to what the issue could be.
Any auto electricians any advice please??
Post #686157 12th Feb 2018 9:08pm
grafty99
Does it have an aftermarket alarm? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #686168 12th Feb 2018 9:32pm
ickle
loose relay under seat
bad connection on speedo pack
Good luck!
Post #686173 12th Feb 2018 9:40pm
Relentless
Standard alarm fitted.
I believe an electrical fault if holding of the ignition otherwise is would fire.
Due to no ignition I doubt I have fuel pumping and glow plugs warming.
Post #686177 12th Feb 2018 9:54pm
grafty99
Possible ignition switch failure? Could just be a coincidence that it's failed at this time. Otherwise check power to under seat fuse box Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #686245 13th Feb 2018 12:39am
jst
Check the multiplug behind the speedo pod. The one that connects the whole pod to the vehicle loom. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686273 13th Feb 2018 9:40am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Isn't there an earthing point on the gear box might you have damaged it or left it off? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #686282 13th Feb 2018 10:12am
agentmulder
Kuwait
Tried locking 4 times on the plip then an unlock? Solved the bowel problem, working on the consonants...
Post #686286 13th Feb 2018 10:36am
Relentless
Recheck earth points all good.
Plipped alarm x 4times a few times.
Starter relay works. (clicks in and out to heater plugs)
Swapped main relays about with those under steering wheel.
All fuses checked again.
Still nothing!!!! Sad Sad
Post #686362 13th Feb 2018 5:34pm
white110
Wales 1997 Defender 110 300 Tdi HT Alaska White
Has the fuel cutoff solenoid got power to it ?
Post #686420 13th Feb 2018 8:59pm
Relentless
Which is the fuel cut off solenoid white110??
Post #686447 13th Feb 2018 10:13pm
jst
There is a large multiplug at the top rear passenger side of the engine, is that connected correctly? part of the loom coming off the engine. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #686452 13th Feb 2018 10:20pm
Relentless
Grey round one above heater box.... yep all in tact..
Post #686463 13th Feb 2018 10:43pm
Scott R
England 1985 Defender 90 Other HT Nato Green
I'm not really familiar with the tdci defender but I have seen this fault on the td5. Has it got a main fusebox with the bolt in fuses? if so take the cover off and check the connection for the main feed from the battery, I've seen the screw come loose and loose connection.
Post #686469 13th Feb 2018 10:56pm
white110
Bulkhead side of the injector pump, single wire.
https://www.youtube.com/watch?v=7C3UNVL0lTw
edit: noticed wrong engine type after posting.
300tdi, loosen an injector pipe and see if fuel leaks, if no multimeter handy.
Post #686480 13th Feb 2018 11:30pm
