Home > Technical > Puma dash with air conditioning? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
You can buy a kit
http://www.paddockspares.com/da2344-air-co...YgQAvD_BwE 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
11th Feb 2018 11:02pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
You'll need an air conditioning system in addition to the switch, Paul.
Paul K Member Since: 01 Dec 2013 Location: St. Thomas, U.S. Virgin Islands Posts: 62 |
I have A/C in my current (pre-Puma) dash. Will those parts work? I kn ow the condenser will be different because I’m putting an LS engine in, not sure about the rest of it...
11th Feb 2018 11:10pm |
I think you'll probably need custom pipes to go from the corvette compressor the the other landrover components. I would have thought you would be able to use the landrover evaporator, condenser and drier. Then corvette compressor and custom pipes.
It might be worth getting in touch with a company who had done the work before 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
11th Feb 2018 11:14pm |
I’m using pickup truck ancillaries, as my engine is an LC9 (Not sure why there are so many engines in the LS category, but there you go).
Agree on getting in touch with the company. Difficult part is, there won’t be Land Rover electronics in it when I’m done- it’ll all be GM! |
12th Feb 2018 12:17am |
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 |
You need a clima compressor, a condenser incl. fan, some pipes for the cooling, a dryer and a heater matrix which supports the matrix heater. Furthermore I think you need an other grille frame for placing the condenser unit.
/Max |
14th Feb 2018 6:30pm |
