Home > Td5 > Dead starter or immobilaser problem? |
voorfrank Member Since: 06 Feb 2017 Location: Schiedam Posts: 37 |
Measure with a multimeter. Then you know if you have 12 volts to the starter or not. It could be a dead starter or no power to the starter.
10th Feb 2018 8:36pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Sounds like starter, had same issue with my tractor completely dead. no noise. Had it refurbished
10th Feb 2018 9:55pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Check if you get 12V on the small wire when you turn the ignition in the start mode. If not it something else if you get 12 v there it is the starting motor. Take it apart, clean it, check the contactpoints and regrease the gearbox.
It will probably be the contact points but don't skip the rest. It isn't that difficult. If you manage to take it off the engine you can refurbish your starting engine too. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
11th Feb 2018 11:52am |
takoon Member Since: 16 Oct 2013 Location: central Posts: 48 |
Hello,
Thanks for all advices. There is NO power to the small wire when ignition key is in the starting mode. So I guess it must be either the ignition itselves or the immobilisior. -99 Td5 90 CSW -09 Jaguar xk4,2 Portfolio |
11th Feb 2018 2:19pm |
Click image to enlarge |
11th Feb 2018 3:24pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 931 |
If it is your starter you can easily repair it yourself. Common failure especially for a 1999, being so old... I had this happen to my 2000MY (built in 99). Kit is super cheap and takes about an hour to fix the burnt out solenoid contacts. Search this site for a step by step how to guide.
Good luck. https://www.ebay.ca/itm/Starter-Solenoid-R...Sw3uBZrYbJ 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
12th Feb 2018 2:56pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
There is also a relay in the dashboard (with the fuses in the middle IIRC) that supplies power to the starter motor solenoid. That relay is energised by the ignition switch starter position with the earth side of the coil provided by the immobiliser. That's how the immobiliser stops you cranking the engine over.
If the relay is clicking when you turn the ignition to the start position then the immobiliser is OK. If it's clicking and you still don't get 12v to the starter solenoid (small wire) then check/swap out the relay. The relay will have white/red wires connected to it. http://www.yorkshireoffroadclub.net/ |
12th Feb 2018 4:45pm |
Hello again fellow Defender owners
Thanks a lot of good advices. Some update: It seems that it could be either the relay between the ignition and starter or the immobilasor. I do messure 12,5 V on the «30» pin on the relay but NO power on the 85(or was it the 86) when I’m turning the key to starting position. I also messure 75 Ohm between 85-86. Is this correct? Is there any possibllity to overrun the immobilasor? How can I messure its wire and what reading should I get? The wire has the colour code: black/orange. davew: the relay doesn’t click at all. -99 Td5 90 CSW -09 Jaguar xk4,2 Portfolio |
12th Feb 2018 6:04pm |
have read below may help you
12th Feb 2018 6:32pm |
Hello,
Good news: problem solved The problem was the control unit for the aftermarket alarm and central locking device. The white and red wire from the crank position on the ignition was going through the control unit wich is probably broken. So, I have disconnect the unit and cleaned out some other old sins wich has been used in the past with previous owners. Thanks again for the good help and advices -99 Td5 90 CSW -09 Jaguar xk4,2 Portfolio |
15th Feb 2018 12:19pm |
