Home > Td5 > Clutch change |
Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 79 |
Hi all.
Has anyone changed their clutch themselves? Mines slipping. Is it doable on the drive? Any special tools needed? Cheers Rich |
10th Feb 2018 10:57am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Definitely doable on the drive. Take your time, you'll have to deal with all the gearbox/transfer box lever linkages.
Engine crane works poked through the passenger door to lower the gearbox down, as does a trolley jack from underneath to take the weight of the assembly. The gearbox/transfer box assembly is heavy, unbalanced and awkward, be careful with it! |
10th Feb 2018 11:37am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
A slipping clutch can be caused by the rocker cover gasket leaking down the back of the block And getting onto the clutch. This happened on mine but I hadn't realised until the gearbox was off
Not saying that's what's causing it but just my experience. Could have saved many hours work if I had realised earler. I changed everything anyway as it was apart but the clutch had loads of life left in it 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
10th Feb 2018 1:47pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2158 |
Ideally you want to change the DMF at the same time which is more involved as the box has to come out.
10th Feb 2018 1:57pm |
