Home > Technical > Replacement Door Hinges
jst
Well my 2010 110 driver door bottom hinge has just about had it, so much play that door has dropped. not great but it is a LR.
for now i have replaced it with a std one. but it got me thinking
should i be looking to fit something better/serviceable. (had a 99 Td5 top hinge failed after 9 years so its not a new problem)
if replacing an upgrading should i look to add some security features too
anyway a little digging found these:
http://optimillraceproducts.com/product_in...ucts_id=33
rears ^^^
and front:
https://houseofurban.co.uk/shop/defender/b...-defender/
cheaper:
https://www.devon4x4.com/da1305-defender-s...inges.html
security wise.
https://goreproducts.com/products/defender...hinge-kits
not sure how much of a pain these would be to fit ^^^
also those bomb proof plates to consider for security.
what have others done?
PS - cant believe the cost £720 for a 110.... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #685121 8th Feb 2018 8:32pm
ericvv
Post #685127 8th Feb 2018 8:43pm
jst
thank you, i remember this thread, but couldnt find it! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #685135 8th Feb 2018 8:52pm
Retroanaconda
I’ve just this week ordered a pair of hinges for the drivers door of mine as the bottom hinge is now worn enough to affect closing. It seems the lifespan for a hinge in regular use is about 8 years or so as I think I fitted these in 2009/2010.
I went for genuine ones, all the others are either ugly or very expensive. Will hopefullly fit them this weekend.
A better solution in my opinion would be to modify genuine hinges to accept grease. There is a thread on this on the LR4x4 forum.
Post #685136 8th Feb 2018 8:52pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Cheaper route... open door, drill 1.5 or 2mm hole in centre of the hinge and pump in grease with a chainsaw grease gun. You can feel the drill touch the hingepin.
Post #685187 9th Feb 2018 5:24am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Another thread on the subject: http://www.defender2.net/forum/topic52994.html
Post #685261 9th Feb 2018 11:35am
geobloke
Top idea! Thumbs Up
Post #685335 9th Feb 2018 5:52pm
Procta
I am looking at this too, I wouldn't mind the gore ones, but I am not sure how plug in play those would be. Anyone know who has them fitted? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #685375 9th Feb 2018 8:21pm
jst
I would also he interested to know if they use studs or bolts in gore ones , anyone on here have them? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #685395 9th Feb 2018 9:27pm
