Home > Technical > Replacement Door Hinges |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8049 |
Well my 2010 110 driver door bottom hinge has just about had it, so much play that door has dropped. not great but it is a LR.
for now i have replaced it with a std one. but it got me thinking should i be looking to fit something better/serviceable. (had a 99 Td5 top hinge failed after 9 years so its not a new problem) if replacing an upgrading should i look to add some security features too anyway a little digging found these: http://optimillraceproducts.com/product_in...ucts_id=33 rears ^^^ and front: https://houseofurban.co.uk/shop/defender/b...-defender/ cheaper: https://www.devon4x4.com/da1305-defender-s...inges.html security wise. https://goreproducts.com/products/defender...hinge-kits not sure how much of a pain these would be to fit ^^^ also those bomb proof plates to consider for security. what have others done? PS - cant believe the cost £720 for a 110.... Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Feb 2018 8:32pm |
Here you go.
Eric http://www.defender2.net/forum/topic55937....+greasable You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
8th Feb 2018 8:43pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2655 |
I’ve just this week ordered a pair of hinges for the drivers door of mine as the bottom hinge is now worn enough to affect closing. It seems the lifespan for a hinge in regular use is about 8 years or so as I think I fitted these in 2009/2010.
I went for genuine ones, all the others are either ugly or very expensive. Will hopefullly fit them this weekend. A better solution in my opinion would be to modify genuine hinges to accept grease. There is a thread on this on the LR4x4 forum. |
8th Feb 2018 8:52pm |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Cheaper route... open door, drill 1.5 or 2mm hole in centre of the hinge and pump in grease with a chainsaw grease gun. You can feel the drill touch the hingepin.
9th Feb 2018 5:24am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Another thread on the subject: http://www.defender2.net/forum/topic52994.html
9th Feb 2018 11:35am |
Top idea! |
9th Feb 2018 5:52pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5183 |
I am looking at this too, I wouldn't mind the gore ones, but I am not sure how plug in play those would be. Anyone know who has them fitted? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
9th Feb 2018 8:21pm |
I would also he interested to know if they use studs or bolts in gore ones , anyone on here have them? Cheers
9th Feb 2018 9:27pm |
