Home > Puma (Tdci) > Steering play |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
My 110 is going to the dealers on monday for them to have a look at the steering, (amongst other things), for the same issue. Although if you can, have a look at the bushes on the steering damper, my ones were very loose. As for the drive it hard advice, I'm not so sure about that. It is not a good idea to let a diesel idle for long periods of time, but I certainly wouldn't thrash it to make up the balance. If you do idle your engine quite a bit I'd be doing oil changes more frequently instead. Tim |
30th Jan 2009 10:41pm |
Well, I've been to the dealers, they are going to replace the steering box and the front prop shaft..... This is the only car I have ever owned that has got newer as time goes by!!!
Tim |
3rd Feb 2009 10:42pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
What do you mean by a couple of inches of play? In which plane?
I guess you don't mean that you can turn the wheel back and forth a couple of inches near full lock. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
4th Feb 2009 8:32am |
The steering play is in the rotation of the steering wheel. It is about 1" in the center and 3" at full lock. It's much more noticable with the engine stopped.
Cheers, Tim |
4th Feb 2009 8:38am |
LRnovice Member Since: 08 May 2008 Location: Cardiff Posts: 59 |
TimmyNZ is right although there doesnt seem to be any play at centre. There is 3/4 inches play on one lock, 2/3 on the opposite lock. I think Ill have the dealer check to see if it is in spec.
Any advice on the driving hard issue? |
4th Feb 2009 9:32pm |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
I have the same issue, I will definately raise it with the dealer when it has it's rear diff replaced next week.
Have many people had this work done. |
13th Feb 2009 10:48pm |
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 |
This is kind of related, but sort of not. Should all MY07+ models have a steering Damper? My SVX does not, which I find Odd. |
28th May 2009 3:04am |
