Home > Puma (Tdci) > Steering play
LRnovice
2008 Defender 90 Puma 2.4 CSW Auto Belize Green
Steering play
I have two questions. When I am on or near full lock there is a couple of inches free play on the steering wheel. This only appears at these positions. Is this normal. Also I have been advised to drive hard regularly to keep the injectors clear. Can anyone advise anything more specific ie how often, how high should I rev it etc. Advice much appreciated
Post #6713 30th Jan 2009 9:56pm
Tim_NZ
Australia
Re: Steering play
My 110 is going to the dealers on monday for them to have a look at the steering, (amongst other things), for the same issue. Although if you can, have a look at the bushes on the steering damper, my ones were very loose.
As for the drive it hard advice, I'm not so sure about that. It is not a good idea to let a diesel idle for long periods of time, but I certainly wouldn't thrash it to make up the balance. If you do idle your engine quite a bit I'd be doing oil changes more frequently instead.
Tim
Post #6714 30th Jan 2009 10:41pm
Tim_NZ
Australia
Well, I've been to the dealers, they are going to replace the steering box and the front prop shaft..... This is the only car I have ever owned that has got newer as time goes by!!!
Tim
Post #6845 3rd Feb 2009 10:42pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
What do you mean by a couple of inches of play? In which plane?
I guess you don't mean that you can turn the wheel back and forth a couple of inches near full lock. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #6851 4th Feb 2009 8:32am
Tim_NZ
Australia
The steering play is in the rotation of the steering wheel. It is about 1" in the center and 3" at full lock. It's much more noticable with the engine stopped.
Cheers,
Tim
Post #6853 4th Feb 2009 8:38am
LRnovice
TimmyNZ is right although there doesnt seem to be any play at centre. There is 3/4 inches play on one lock, 2/3 on the opposite lock. I think Ill have the dealer check to see if it is in spec.
Any advice on the driving hard issue?
Post #6893 4th Feb 2009 9:32pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I have the same issue, I will definately raise it with the dealer when it has it's rear diff replaced next week.
Have many people had this work done.
Post #7251 13th Feb 2009 10:48pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Re: Steering play
Tim
This is kind of related, but sort of not.
Should all MY07+ models have a steering Damper?
My SVX does not, which I find Odd.
Post #11351 28th May 2009 3:04am
