Home > Maintenance & Modifications > Td5 Self Service |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2169 |
Nope none on the diffs. Just engine/sumo and gearbox.
Sump eBay Item No. 112435773683 GB washer eBay Item No. 323050045997 If you are draining the diffs its worth fitting magnetic drain plugs. Not essential but a good idea |
8th Feb 2018 8:29am |
Crossfit_Pete Member Since: 07 Feb 2018 Location: N.Essex Posts: 168 |
Thank you1
8th Feb 2018 8:54am |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Good source or make of magnetic drain plugs for the diffs? Will be doing mine soon.
8th Feb 2018 9:49am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Are they not the same on a disco2? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
8th Feb 2018 10:30am |
Disco2 diffs are the same.
The xcess 4x4 mag plugs are fantastic but the Britpart ones are good enough! |
8th Feb 2018 10:53am |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
so you replace the crush washers? Is thee any special torque setting needed for any of the nuts or just do um tight? |
8th Feb 2018 2:01pm |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
When refilling the diffs, whatever you do, don't do what I did. I attempted to refill it using a funnel, with a short (2") piece of garden hose on the end, such the the funnel could be held upright, with the hose making the 90deg bend into the vertical refill hole. Yes, the piece of hose fell off and into the diff!!!!! A couple of hours with my fingers in both holes and eventually I got it out. Was a happy moment. Was on the verge of opening the diff to get it out with whatever can of worms that would have been, also considered just leaving it in there and driving it around and letting the gears mash it up. Was a right pain, I could get hold of it by either end with one finger in the fill hole and one in the drain, but couldn't do anything with it, kept losing it, was in total despair! Eventually managed to thread a bit of wire through the center of it and wiggle out. Just as I got the job finished a mate rocked up to help, and kindly said "oh you should have asked, I have an oil pump you could have borrowed"
8th Feb 2018 2:36pm |
Yes, always a new copper washer. Not so tight on the engine sump plug, it's going into alu... infact the torque setting is lower than what my wrench goes down to, it just feels wrong when you consider what is at stake! |
8th Feb 2018 2:48pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
I got one of these last time they were on offer -
https://www.lidl.co.uk/en/Non-Food-Offers.htm?articleId=10632 Great for filling the axles and transfer box, just need to make sure the thicker pipe is used on the outlet side and shortened to get the pump fairly close to the axle. I've not tried it for sucking old engine oil out as I prefer to drain it normally, engine nice and hot then front wheels on ramps to get better clearance but also to tip the sump backwards to get every last drop out. |
8th Feb 2018 3:05pm |
What brand mtf 94 does everyone buy and where from. Seems pretty dear everywhere and they're all makes I've never heard of... Only normal one I've found is carlube. £8.99/L
13th Feb 2018 1:41pm |
Finally getting round to this any recommendations on engine oil ? Semi synthetic 5w30 right?
28th Oct 2018 7:03pm |
