Home > In Car Electronics > dual battery (parallel setup) |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Use one of the FIA battery isolator switches with the auxiliary contacts on the bottom. From memory there is one normally open and one normally closed contact. Use ome of these to trigger your relay.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
8th Feb 2018 6:39am |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 |
So the FIA switch (From looking at these on internet)
Provides the manual battery connection (200Amp - 1000amp Crank) all ok the 4 pole connector at the base - i take it is : 2 circuits (1 NO/1 NC) - i would use these to trigger the DC/DC isolator Relay???? |
8th Feb 2018 7:11am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 636 |
Do you need the DC/DC converter between the batteries? Is it much simpler without it and just direct charging both batteries from alternator. You need only some sort of switch (I prefer heavy duty relay/solenoid) to disconnect batteries, with not running engine. And for the case od death battery a way, how to bridge the solenoid - with additional manual switch, or simple with just reconnecting wires. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
8th Feb 2018 8:06am |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 |
What I used on my old freelander was a voltage sensitive relay and two key isolators, but I removed one key out of the vehicle. This means that I could have either the VSR in, or the manual bridge in and the VSR disconnected. It worked a treat. North Cumbria Search and Rescue - Team Leader
8th Feb 2018 8:50am |
Yes 02' 110 TD5 Double Cab Rebuild Thread |
8th Feb 2018 8:54am |
