Home > In Car Electronics > dual battery (parallel setup)
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Forum,
i have a DC/DC setup for a dual battery setup which unfortunately this setup does not allow for using the Aux battery as a backup starter (parallel or only).
I have been advised by the DC/DC supplier i will need to isolate the DC/DC unit out of the circuit if I bridge the Aux and th Starter. This is very easy as the unit is 25 Amp and this can be a relay.
Equally via a high duty switch i can manually 'bridge' the AUX/Starter battery - again all good.
the question is the join the two to prevent 'fudge ups', e.g. relay to isolate DC/DC energised when the manual Heavy duty switch is 'on'
if i connect POS from Start bat to one pole of the heavy duty switch and the POS of the AUX bat- bot are energised - so how to trigger the relay?
Post #684921 8th Feb 2018 1:03am
rallysteve
Use one of the FIA battery isolator switches with the auxiliary contacts on the bottom. From memory there is one normally open and one normally closed contact. Use ome of these to trigger your relay.
Post #684936 8th Feb 2018 6:39am
itolond
So the FIA switch (From looking at these on internet)
Provides the manual battery connection (200Amp - 1000amp Crank) all ok
the 4 pole connector at the base - i take it is :
2 circuits (1 NO/1 NC) - i would use these to trigger the DC/DC isolator Relay????
Post #684937 8th Feb 2018 7:11am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Do you need the DC/DC converter between the batteries? Is it much simpler without it and just direct charging both batteries from alternator. You need only some sort of switch (I prefer heavy duty relay/solenoid) to disconnect batteries, with not running engine. And for the case od death battery a way, how to bridge the solenoid - with additional manual switch, or simple with just reconnecting wires. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #684948 8th Feb 2018 8:06am
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
What I used on my old freelander was a voltage sensitive relay and two key isolators, but I removed one key out of the vehicle. This means that I could have either the VSR in, or the manual bridge in and the VSR disconnected. It worked a treat. North Cumbria Search and Rescue - Team Leader
Post #684955 8th Feb 2018 8:50am
rallysteve
Yes Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #684957 8th Feb 2018 8:54am
