Home > Maintenance & Modifications > Td5 Self Service |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2230 |
Personally genuine parts only for my td5 02' 110 TD5 Double Cab Rebuild Thread
7th Feb 2018 7:12pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Can it all be done without jacking it up on stands? Will hunt down some videos on YouTube.. great info on hear thanks
7th Feb 2018 7:40pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2173 |
Dont need stands.
Run the engine for 5 mins before draining, makes it quicker. |
7th Feb 2018 7:43pm |
Cool
What is best to drain oil into ready to take to recycling center, is it a tray job then decanter into something else? Or can you get special all in one thing for the job.. |
7th Feb 2018 7:45pm |
Crossfit_Pete Member Since: 07 Feb 2018 Location: N.Essex Posts: 168 |
&t=142s
7th Feb 2018 7:52pm |
7th Feb 2018 8:02pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
You can get a genuine service kit from LR for about £79
7th Feb 2018 8:21pm |
I get mine from Island 4x4, always good service:
http://www.island-4x4.co.uk/defender-disco...27858.html Steve 02' 110 TD5 Double Cab Rebuild Thread |
7th Feb 2018 8:27pm |
The cheapest kit on eBay is about £11.95, inc postage, given Land Rover don't make filters there must be a happy medium?
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 714 |
I've bought a few services kits from Advanced Factors, they supply OEM brand filters kits ie Mann, Cooper along with the recommended oil and even include sump washers.
Putting a plastic bag over the oil filter after loosening it prevents dribbling oil across the engine bay when you remove it. Likewise a bag over your hand when removing the sump plug prevents the delightful experience of oil running down you arm whilst holding onto the plug rather than letting it fall into the bucket below. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
7th Feb 2018 8:34pm |
Super tool. Worth it's weight... |
7th Feb 2018 8:35pm |
Since you are planning a full service may I suggest the gent greases his nipples....
7th Feb 2018 8:36pm |
Ahhh forgot about the crush washers!
Theres one on the engine/sump drain plug and one on the gearbox drain plug. You also need 22 or 32mm spanner i forget which. 1/2" ratchet/drive for the diffs and a largeish (cant remember the exact size) torx bit bit for the TX box. Make sure the torx bit fully seats in the hole. |
8th Feb 2018 8:02am |
Are there copper washers on the diffs? If so any idea what sizes?
8th Feb 2018 8:10am |
