Home > For Sale & Wanted > [For Sale] Safety Devices 110 Internal Roll Hoop |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8050 |
can this be fitted as stand alone fit or is it meant to be fitted with other braces? am interested Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Feb 2018 12:54pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Hi there!
Yes Stuart at Foley sold it to me on that basis as I didn't want a full cage. There is no attachments for linking it to other parts. If it helps Stuart also sent me this when I asked about fitting - although it's pretty obvious once you have it in place: "· The foot pushes up to the head of the bolts, and one floor screw will need to be removed so that the foot sits on the floor flat. · The door stay has to be shortened by about 5mm - and the hole re drilled." Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
6th Feb 2018 1:00pm |
the bottom rear door stay has to be shortened? so would limit opening? Cheers
6th Feb 2018 1:54pm |
Hi James,
The opening would be identical. Basically the foot of the hoop obscures the current termination for the stay. Built into the foot is a stud for the stay to attach to in its place - I guess the stay would be slightly too long and prevent the door closing in this position unless it was shortened. You can just see the stud sticking up in my 2nd picture, right near the left edge as the photo is taken. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
6th Feb 2018 1:57pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
No need to shorten, but on my cage the thread of the bolt was smaller diameter,. So I had some spacers made to take up the slop.
Note Door card is fitted.....well that was before I tried to shut the door Just check before final fitting that the hoop doesn't foul the cards.....earlier cages had a slightly different shape it seems to later ones... the early cards were not as pronounced. Click image to enlarge |
6th Feb 2018 6:16pm |
can it be fitted by passing in through the doors or roof off job? Cheers
6th Feb 2018 7:44pm |
Romadog have you any pics of the top part of the fitting Cheers
6th Feb 2018 7:46pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1845 |
EDIT - apologies - I'm going to bow out of this one. 100% I normally stand by offers like this, but i've had some time to think about it, and realised I need to think some more about it...
Good luck with the sale. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... Last edited by donmacn on 7th Feb 2018 6:12pm. Edited 1 time in total |
6th Feb 2018 8:06pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3754 |
Romadog.
Have you a picture at the top near where your head goes? As another has mentioned can this be fitted by passing through the car. Would this offer much support having no side supports? As I'm looking at full cages but this is better than nothing? Where do you buy one new from, Thanks |
6th Feb 2018 8:20pm |
Don't want to muck up this For Sale thread .......
How do you get the hoop in? Well that's a good question You will need two people so find a friend first. Having the rear seats out of the way will help. The fronts as far forward - out is better. Also the floor came out so that I could drill the brackets below, clean holes and re-paint. The hoop goes in through the side doors if the floor is out - door seals removed as well. The brackets on the top which go to the roof to pick up on the front hoop (Camel Trophy style). I cut mine off and repainted the hoop before fitting as I dont have that front section on mine -dont like it. Prefer the 50th/ G4 version. Doesnt join up though I also had a bracket welded to the underside of the hoop for cross bracing. This was removed too before i hit my head on it. My hoop is part of internal cage to rear so is supported to the rear as well. If you have wide Corbeau style seats then as long as you have short legs then you will be ok. Remember these cages were designed for standard seats. |
6th Feb 2018 10:58pm |
