Home > Puma (Tdci) > Clutch choice 2.4
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Clutch choice 2.4
Following the death of my engine (cam chain stretch at 110k miles) I'm having a think about what clutch to have fitted whilst the engine is out.
I'm considering genuine, OEM or Clutchfix.
All thoughts and practical experiences, good or bad, welcome.
Thanks
Post #683660 2nd Feb 2018 5:07pm
Well the Genuine new type seems a lot better than the early spec.
Other than that very difficult to say really, I went from the old type to the new spec. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #683670 2nd Feb 2018 5:53pm
MartinK
Ashcroft (who I guess know what they are talking about?) sell the AP
http://www.ashcroft-transmissions.co.uk/mi...lutch.html
I think if mine fails, I will do their Auto Conversion... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #683672 2nd Feb 2018 6:07pm
hornet
Re: Clutch choice 2.4
Thanks
This is a really difficult question in my eyes. Lots of makes on the market, all claiming they solved the spring-problem. Mine started rattling again thousand of km ago, so having the same question in mind. Rather expensive, but sounds not too bad.... Will no longer trust the genuine one.
http://www.defender2.net/forum/topic57632.html
Post #684290 5th Feb 2018 2:19pm
shropshiredefender
Thanks all. Have ordered the Clutchfix complete kit after much research.
Post #684361 5th Feb 2018 7:51pm
pannawonica
Australia
I don’t doubt the clutch fix supplied parts are an upgrade, however if you do I search I would be inclined to give weight to the way DG went! 👍
Post #684463 6th Feb 2018 8:41am
leeds
OK we at 4x4overlander stock the Clutchfix kit. I am not a mechanic and if I do not understand something I tend to ask questions.
The clutch that DG went for is a clutch by Sachs. That clutch is an extended life clutch made for Ford Transit 4x4 engines.
Now the flywheel on the Ford engine is a Dual Mass Flywheel (DMF) and has springs inside the clutch cover to take up wear. The flywheel on the 2.4 Puma is a single mass flywheel.
Whilst the two different clutches are within millimetres the same size and I do not doubt that the Ford Transit clutch works in a 2.4 Puma and is slightly cheaper there are some serious questions to be asked.
What is the clamping force of the Sachs clutch? What differences is there in a clutch designed for a DMF being used on a single mass flywheel? Transit 2.4 engines are rarely remapped for more power/torque whilst Puma 2.4 engines are frequently remapped.
I would suggest that the use of such a clutch is a 'grey' area and would suggest caution before going down that route. Yes that route is slightly cheaper in initial purchase price but is it the best option long term?
Brendan
Post #684491 6th Feb 2018 11:12am
