Home > Puma (Tdci) > Clutch choice 2.4 |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Following the death of my engine (cam chain stretch at 110k miles) I'm having a think about what clutch to have fitted whilst the engine is out.
I'm considering genuine, OEM or Clutchfix. All thoughts and practical experiences, good or bad, welcome. Thanks |
2nd Feb 2018 5:07pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Ashcroft (who I guess know what they are talking about?) sell the AP
http://www.ashcroft-transmissions.co.uk/mi...lutch.html I think if mine fails, I will do their Auto Conversion... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
2nd Feb 2018 6:07pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
This is a really difficult question in my eyes. Lots of makes on the market, all claiming they solved the spring-problem. Mine started rattling again thousand of km ago, so having the same question in mind. Rather expensive, but sounds not too bad.... Will no longer trust the genuine one. http://www.defender2.net/forum/topic57632.html |
5th Feb 2018 2:19pm |
Thanks all. Have ordered the Clutchfix complete kit after much research.
5th Feb 2018 7:51pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I don’t doubt the clutch fix supplied parts are an upgrade, however if you do I search I would be inclined to give weight to the way DG went! 👍
6th Feb 2018 8:41am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
OK we at 4x4overlander stock the Clutchfix kit. I am not a mechanic and if I do not understand something I tend to ask questions.
The clutch that DG went for is a clutch by Sachs. That clutch is an extended life clutch made for Ford Transit 4x4 engines. Now the flywheel on the Ford engine is a Dual Mass Flywheel (DMF) and has springs inside the clutch cover to take up wear. The flywheel on the 2.4 Puma is a single mass flywheel. Whilst the two different clutches are within millimetres the same size and I do not doubt that the Ford Transit clutch works in a 2.4 Puma and is slightly cheaper there are some serious questions to be asked. What is the clamping force of the Sachs clutch? What differences is there in a clutch designed for a DMF being used on a single mass flywheel? Transit 2.4 engines are rarely remapped for more power/torque whilst Puma 2.4 engines are frequently remapped. I would suggest that the use of such a clutch is a 'grey' area and would suggest caution before going down that route. Yes that route is slightly cheaper in initial purchase price but is it the best option long term? Brendan |
6th Feb 2018 11:12am |
