Home > Wheels & Tyres > What wheel is this and what option should I go for?
Which option
A
35%
 35%  [5]
B
64%
 64%  [9]
Total Votes: 14
simon67
England 2004 Defender 90 Td5 HT Rutland Red
My son is doing up a N/A 2.5 90 and it currently has the following wheels on it
Loads to do on it, but as a surprise in the future, should i
A - get the current ones stripped, powder coated etc and resprayed white
B - sell the current ones and get him genuine wolfs in white
If B, what is a set of the current four worth against a new set of white OEM Wolfs?
Post #683176 31st Jan 2018 4:24pm
JOW240725
Can't help with what that wheel is I'm afraid. Genuine wolfs are around £67 each or copies from £50 each. I'm not sure it's worth refurbishing, might as well buy new? Unless you want a non-standard colour? James
Instagram @suffolk_rovers
Post #683179 31st Jan 2018 4:39pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I may be wrong but it looks like a Discovery 1 steel wheel to me... Cheers Don.
Post #683180 31st Jan 2018 4:39pm
JeremyJ
Disco 1 steel wheels.
They look quite good painted and slightly different to Wolfs (which do look awesome!)
Post #683181 31st Jan 2018 4:40pm
Yeah, D1 wheels. They're a good wheel - very strong - and 7 inch wide, too.
I had them fitted to a 110 years ago:
 Darren
Post #683197 31st Jan 2018 5:39pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
They used to be really common in D1 days when alloys were mainly a dealer fit option so the dealers had lots of these spare. I think I gave about £100 for a set of 5 back in the 90’s. Worth a little more than second hand tubeless Defender rims due to the width. So not really very much. If on a tight budget refurbish these. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #683219 31st Jan 2018 6:56pm
Litch
If I recall correctly the D1 steel wheel had a slightly reduced offset but it was negligible in use.
Agree about lots of them being surplus to requirements when the D1 was released (and people upgrading to alloys straight from the factory), dealers could hardly give the steels wheel away and I know of at least one person who was given them by the local dealer to save them having to scrap them (they went onto his S11 a treat). ONE LIFE, GET IT!
Post #685058 8th Feb 2018 5:08pm
camelman
The wheels are going for 50-100 quid on eBay for a set
Post #685070 8th Feb 2018 5:36pm
No, they're 33mm, the same as LR alloys. Darren
Post #685097 8th Feb 2018 7:16pm
yostumpy
Yes I think they have. a 33mm offset, means that the back of the wheel is closer to the trailing arms than a 20mm offset, Then 0 mm offset means the wheels look deeper , then modulars are a negative offset, say -20mm , this means they stick out further. Did the Disco wheels and 235's reduce the steering lock by much?
Post #685352 9th Feb 2018 6:53pm
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Defender 90 td300 My 1998
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #685382 9th Feb 2018 8:40pm
