Home > Wheels & Tyres > What wheel is this and what option should I go for? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7905 |
Can't help with what that wheel is I'm afraid. Genuine wolfs are around £67 each or copies from £50 each. I'm not sure it's worth refurbishing, might as well buy new? Unless you want a non-standard colour? James
31st Jan 2018 4:39pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
I may be wrong but it looks like a Discovery 1 steel wheel to me... Cheers Don.
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Disco 1 steel wheels.
They look quite good painted and slightly different to Wolfs (which do look awesome!) |
31st Jan 2018 4:40pm |
Yeah, D1 wheels. They're a good wheel - very strong - and 7 inch wide, too.
I had them fitted to a 110 years ago: Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Jan 2018 5:39pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
They used to be really common in D1 days when alloys were mainly a dealer fit option so the dealers had lots of these spare. I think I gave about £100 for a set of 5 back in the 90’s. Worth a little more than second hand tubeless Defender rims due to the width. So not really very much. If on a tight budget refurbish these. 1995 Defender 110 CSW
1971 SIIA Lightweight |
31st Jan 2018 6:56pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 762 |
If I recall correctly the D1 steel wheel had a slightly reduced offset but it was negligible in use.
Agree about lots of them being surplus to requirements when the D1 was released (and people upgrading to alloys straight from the factory), dealers could hardly give the steels wheel away and I know of at least one person who was given them by the local dealer to save them having to scrap them (they went onto his S11 a treat). ONE LIFE, GET IT! |
8th Feb 2018 5:08pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3372 |
The wheels are going for 50-100 quid on eBay for a set
8th Feb 2018 5:36pm |
No, they're 33mm, the same as LR alloys. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
8th Feb 2018 7:16pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Yes I think they have. a 33mm offset, means that the back of the wheel is closer to the trailing arms than a 20mm offset, Then 0 mm offset means the wheels look deeper , then modulars are a negative offset, say -20mm , this means they stick out further. Did the Disco wheels and 235's reduce the steering lock by much?
9th Feb 2018 6:53pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Defender 90 td300 My 1998
Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
9th Feb 2018 8:40pm |
