![]() | Home > My Defender > Newbie with a TD5 |
I'd say your injector washers and seals need changing (use genuine only) check to make sure your oil level isn't rising and smell for diesel. If your pump was making a lot of noise it'll be letting air in past the seals. When you did the fuel purge it puts some pressure back into the system. Ray
Mine had the same symptoms and I changed the pump for a genuine one at great expense and the seals and washers were the problem which only cost about £20/30
![]() My build thread http://www.defender2.net/forum/topic17615.html |
