Home > My Defender > Newbie with a TD5 |
I'd say your injector washers and seals need changing (use genuine only) check to make sure your oil level isn't rising and smell for diesel. If your pump was making a lot of noise it'll be letting air in past the seals. When you did the fuel purge it puts some pressure back into the system. Ray
30th Jan 2018 8:24pm |
Mine had the same symptoms and I changed the pump for a genuine one at great expense and the seals and washers were the problem which only cost about £20/30 Ray
30th Jan 2018 8:26pm |
