Home > Maintenance & Modifications > Webasto Problems |
They are similar to Eberspachers and mine will follow that sort of problem and 99% of the time it is fuel starvation, check the line from your tank to the pulse pump. on the Eber there is a gauze filter tucked away in the inlet side of the pump, this is usually the problem, just needs teasing out and blown through with an air line. Hope that helps
29th Jan 2018 1:19pm |
WhathaveIdone! Member Since: 04 Feb 2016 Location: Sakhalin Island Posts: 27 |
I am having a similar problem - the webasto starts up, but at the time that I expect to hear the clicking / pulsing of the fuel pump, it goes into purge/shut down. Have been struggling to diagnose as it only happens when the temperature gets below -15C (i.e. when I really need it!)
I have considered the possibility of it being a filter issue, but I thought I would at least hear the 'click' of the pump, even if the filter is blocked. I am using winter diesel and am not having any problems with fuel supply to the engine. Have come to the conclusion that the only way of getting a correct diagnosis is if I get the correct software and diagnostic cable. Am planning to take it to a local specialist, but also on ordering a cable off ebay for future use. Best of luck! |
30th Jan 2018 8:40am |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 |
Yeah I've had fuel issues before and the pump has always started then the flameout occurs.
I notice if I start the heater when the engine is at temperature the heater will continue to circulate so the circulation pump definitely works as must the combustion air fan due to the noise. The exhaust doesn't appear to be blocked and I can feel airflow around it during the purge. Saw something on a rover forum https://the75andztclub.co.uk/forum/archive/index.php/t-71982.html suggesting a glow pin or knackered pcb |
30th Jan 2018 10:36am |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 428 |
Mine was playing up and there was no clicking of the fuel pump
I disconnected the fuel line as it leaves the pump and the pump then pulsed fine Blew the line out with compressed air and problem resolved |
30th Jan 2018 10:41am |
Interesting, haven't checked the heater end of the line so will try that
30th Jan 2018 10:51am |
Mine does this sometimes if the battery voltage is low. If I first start the engine (so alternator is working) or have the battery charger connected, no problem. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
30th Jan 2018 4:40pm |
