![]() | Home > Series Land Rovers > My Series III |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Awesome toylander! James
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3795 ![]() ![]() |
OK so Sunday was the morning spent at the Garage where my toy is... rustproofing and general sort at the back. Then home as the little lad was out to spend time on the toylander (see other thread)
Finished covering the rear under the boot with rust proofing and wax oil. ![]() Click image to enlarge Then as I was waiting for stuff to dry decided to do the rear cross member. ![]() Click image to enlarge ![]() Click image to enlarge |
An update
![]() ![]() ![]() MOT passed today ![]() A couple of advisories - Oil Leak.... ![]() ![]() - A track rod ball end joint dust cover deteriorated but preventing ingress of dirt? - Water Leak -- Now the water leak is the water pump on its way out so while its at the garage he will change this for me if I get the parts, pipes. Anything else I need ?? (fan belt) So I now need to sort my garage out that was cleaned up for this, but then I did the toylander.. I just hope it fits. Happy though as it will be home to mess about with soon, ![]() |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
don't know how you coped having it away that long!
![]() my youtube channel |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 ![]() ![]() ![]() |
Did you not have new rear bumper grab handles? You should have taken the old ones off and sand around them just in case the new ones are slightly different in size.
^ I will sort again once home.
I've bought so many bits over the months I do forget what I have, I should have a list. ![]() Well today I stopped on way home and its having its new Water pump, fan belt, pipes and clips etc. ![]() I was going to do this but he said the bolts could snap and they are a bit of a pain if that happens so as its there he said he will do it within the price we agreed... So tonight I need to get change it from SORN to 'Tax' it ready to use ![]() How exciting ![]() Click image to enlarge |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 512 ![]() ![]() ![]() |
Do you know why the spare wheel carrier is mounted so low on the door? It doesn't look like you could actually put a wheel on that?
Looking great btw ![]() '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 632 ![]() ![]() ![]() |
It was an attempt to stop the doors cracking up so much from weight of the wheel. This is back before they even added the third hinge to the back door. It didn’t really work and stopped you using the towball without removing it. 1995 Defender 110 CSW
1971 SIIA Lightweight |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 ![]() ![]() ![]() |
Well done, Nice to see another S3 being rebuilt, they were much maligned in my youth as the rustiest rovers, should see the state of the one I'm rebuilding for swmbo.
Basically new chassis and bulkhead and rebuild/refurbish of all the major components. Just ditch those horrible 6.00s and get it onto 7.50s and itll look the business. I agree, never understood the low spare wheel mounting, that I agree with the previous poster, the doors do fatigue especially with 7.50s on. What I found with my first 109 was the steel frame cracked, so I fitted a spare wheel carrier, this then fatigued the rear tub! shoved it on the bonnet, makes it bloomin heavy to open and reduces visibility, shoved it on the roofrack, a ![]() ![]() Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
^ Thanks
I have already some wheels I have sanded, primed and painted Limestone... ![]() Click image to enlarge Well today, Probably at least 9 months since I have bought the SIII, I dropped my Defender off some some work and Given Hobgoblin now has the welding and a MOT I've taken this to work ![]() ![]() ![]() ![]() ![]() Click image to enlarge Already its have favourable comments as being well cool ![]() |
Crossfit_Pete Member Since: 07 Feb 2018 Location: N.Essex Posts: 168 ![]() ![]() ![]() |
Looks very nice, well done 👍
Blacksheep Member Since: 10 Dec 2017 Location: Highlands Posts: 190 ![]() |
I've enjoyed reading about your journey, well done. Time is precious, waste it wisely...
Defender 90 D200 |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
Nice one 👍 looks great 😎
Stephen. |
Sweet as a penny
