Home > Technical > First "issue"
davybull
United Kingdom 2004 Defender 110 Td5 HT Masai Red
First "issue"
Took the Defender out this morning.
Sat at the traffic lights and switched the radio on. There was instantly a noise like a relay chattering which disappears when I turn the radio off. Tried it a few times but the same thing happens. Standard LR radio (photo below).
Is the radio controlled by a relay or is it likely to be the unit itself? Not had time to look.
Post #681521 24th Jan 2018 11:03pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Anything to do with the CD player?
Post #681524 24th Jan 2018 11:08pm
grafty99
Yes CD player fault? Or has it had an electronic ariel fitted? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #681525 24th Jan 2018 11:09pm
Djcla
maybe im not alone when it comes to the radio surround not staying in place and popping out at the bottom
Post #681580 25th Jan 2018 12:19pm
Sockpuppet
Some people wire ignition feeds from the radio so it's likely that it could be a relay that another owner added that is being powered from the radio. Possible Sub that has been removed?
Post #681583 25th Jan 2018 12:37pm
VVS210
Had that same head unit in my old D2 & it used to 'chatter' when it was cold & I tried to play a CD. Radio worked fine & once things had warmed up inside the CD player would work fine too. Would imagine that in a Defender the symptoms would be more frequent!
Post #681585 25th Jan 2018 12:46pm
davybull
No Electric Ariel Grafty.
It happens when I switch it on without a CD in it.
I'll maybe get a chance to make some radio removal pins tomorrow and have a look.
Time is short!! Crying or Very sad
Post #681613 25th Jan 2018 4:05pm
davybull
No you are not alone!
Going to try and sort that at the same time just for the moment but may get one of the MUD fascia plates soon.
Post #681615 25th Jan 2018 4:18pm
DAZ110
If it doesn't make the noise with a CD in, but it does make a noise without a CD, then surely it must be the internals of the CD player that are at fault...?
...and a couple of thin screw drivers in the holes will probably get the radio out of the facia without to much trouble.
Post #681628 25th Jan 2018 5:17pm
Nutter
Does it make a noise with the engine off it could be a bad ariel earth.
Post #681644 25th Jan 2018 6:51pm
