![]() | Home > Technical > td5 not holding boost |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Might be worth removing and cleaning the map sensor
![]() But it could be a pipe or the intercooler. No strange noises is presume? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Any black smoke?
Actuator move freely? |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
cor , you lot are fast , no strange noises cos the tyres n straight thru pipe are loud enough , its got a new big intercooler , fancy pipes etc , i`ll change the map sensor , as i have a spare , the one in is clean , a thought , could the turbo not have enough puff with the bigger intercooler i wonder
no smoke , new actuator , found the old one seized solid at the weekend , hence why my nanocom was plugged in to test n set up |
New intercooler and pipes would be my fist port of call then. Anything that has changed from before should be the first thing to check.
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Also if you are running a boost limit box that could have gone faulty. But definately check what's changed first
Yeah what boost your running? 18psi is the limit. Any above needs a boost box or uprated MAP sensor + raised boost limit
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Leaky new silicon pipes would be my guess. Checked they've not slipped and the clips are tight tight. Then intercooler
Hello everyone , i’ve Checked the pipes , but will carry on tests after the weekends pay/play day . The boost is around 19psi by google . Ady
Standard boost on a Td5 is 1 Bar (~15psi) 19psi is right at the upper limit of what the ECU will allow before boost cut strategy kicks in. 2002 90 Td5 Station Wagon
