![]() | Home > Maintenance & Modifications > Dashboard mods |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 ![]() ![]() |
Off the top of my head, a couple of bits worth doing with the dash removed are adding a second washer jet and swapping the wiper relay for the VW type that gives intermittent wipers, i've also added a common earth for various accessory switches, usb ports etc so it's often worth adding a multicore wire or bunch of wires from the battery box into the dash area so you can add future switches without having to remove the entire dash.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Extra sound barriers to reduce some engine noise
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Depends a little on the model and age but i would definitely remove and at least clean/grease the wiper mechanism or better still replace the spindles and rack. 02' 110 TD5 Double Cab Rebuild Thread
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Add another 12v socket.
X-eng column lock. Route wiring or condition for later installation of Bluetooth mic for head unit or switches for work lights at rear etc... |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
All great ideas!
I have new window washers already somewhere in the shed, didn't think about that so they will be installed. Some Dynamat won't go astray either. Running some cable for later use is also a great idea! |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
Whilst the dash is out, it's well worth going over the outside with a hosepipe and see if there are any minor leaks coming in.
As for the extra cables, if you have the space then run a length of conduit down from behind the radio to the transmission tunnel, it makes it much easier to poke cables through if you want to add more at a later date. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2193 ![]() ![]() |
Soundproofing!! Most the noise in a fender comes from the bulkhead
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
As already stated - wiper mechanism (refurb of replacement) and conduit and or spare loom for future mods.
Best of luck ![]() |
