Home > Technical > Exhaust suggestions for Defender Puma 90 2.4
Peterwat
Australia 2010 Defender 90 Puma 2.4 HT Fuji White
Hi all,
I have a DP chipped Puma 2.4 90 series and would like to fit a exhaust, 2 reasons for this is maybe get better performance but more importantly get a bit of a note to the engine. What I have done too date is to remove the muffler and resonator to test what she sounded like...result ..nothing it sounded almost exactly the same.
Anyone out there been able to improve on engine note or better still recommend an exhaust.
thanks,
Peter
Post #679102 17th Jan 2018 2:15am
grafty99
I think you will find for best results you need to remove the catalytic converter Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #679119 17th Jan 2018 7:52am
Naks
Yep, remove the cat, and if you want a louder exhaust noise, cut out the centre silencer box and replace with a straight pipe Thumbs Up --
Post #679120 17th Jan 2018 7:57am
Peterwat
My local exhaust practitioner is a coward, is the cat conv a combination with DPF? If yes he refuses to remove
Post #679181 17th Jan 2018 10:59am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
No DPF on a 2.4 just the Cat.
I’m running a straight through system on my 2.4 just with the standard rear silencer in place, still not that noisy but does sound nice under load. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #679193 17th Jan 2018 11:29am
Then in 9 months time, change it back to standard because you keep getting a headache from the droning....
My Td5 was like this... went back to standard and got no reduction in performance. Laughing
Post #679445 17th Jan 2018 10:07pm
ian series 1
Mines ok on a run, you only notice the exhaust note if you have the passenger window down,
Been like that for nearly 4 years now. Wink 80" 80" 86" 88" 90"
Post #679450 17th Jan 2018 10:16pm
grafty99
My Td5 gets on my nerves every few months. I put the silencer back in, am amazed how quiet it is, get bored after a few weeks, then put straight through back on. Then repeat Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #679482 17th Jan 2018 11:13pm
grafty99
Can do a centre exhaust section change in about 10 minutes now including getting the tools Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #679483 17th Jan 2018 11:14pm
Peterwat
Is there anything available of the sheld here in Oz,preferably in Victoria or online. Btw thanks for the info so far
Post #679533 18th Jan 2018 5:41am
Peterwat
Correction
Meant to say "off the shelf"
Post #679534 18th Jan 2018 5:42am
pannawonica
Australia
I got my centre box pipe from rovacraft, it fitted ok but was a little too long. My thinking it was a generic TD5 one about $90 at the time! However the stainless decat pipe kit came from Alive and was excellent in every way. In addition with the 175hp remap and ultimate intercooler plus silicon pipes. The cat as said for a better sound has too go, this is also a great benefit for heat mitigation with other mods! Thumbs Up
Post #679803 19th Jan 2018 2:25am
Peterwat
Thanks all.
Post #680031 19th Jan 2018 9:18pm
Peterwat
A couple of post suggest that the cat converter can have the guts bashed out so it is straight through then the centre muffler can be simply replaced with a straight pipe,apparently this modification is pretty cheap and the centre muffler can simply be refitted when or if required
Post #680076 20th Jan 2018 5:36am
Peterwat
I've removed the cat pipe, all I can see in there is what looks like insect screen. Where is the white substance that one just "bashes out" as discussed on another forum.
Have I been snowed
Post #680310 21st Jan 2018 3:08am
