Home > Puma (Tdci) > Heat related power loss, any ideas?
biffabacon67
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Right guys, as stated above i have a 2010 110 with 75000 on the clock. Its absolutely fine and normal just driving around the doors. Loads of power and acceleration. But, if i attempt to drive 8-10 miles the power and feel seems to tail off and disappear, by 12 miles it couldn't pull the skin off a rice pudding. But let it cool down and its back to normal.
Post #678600 15th Jan 2018 8:43am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Any indication of overheating on the temp gauge? Might be worth hooking up diagnostics to get a more accurate measure of temperature whilst driving.
Guessing you're getting no engine check light?
Does the power fade or is there a a sudden loss?
Post #678609 15th Jan 2018 9:04am
biffabacon67
Sorry, i should have said. NO overheating, temp gauge normal, and no warning lights on the dash. Power fades away.
Post #678611 15th Jan 2018 9:06am
BenB8man
Try unplugging your MAF and giving it a test.
Post #678618 15th Jan 2018 9:21am
biffabacon67
Cheers Ben, I'll give it a go!
Post #678627 15th Jan 2018 9:45am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Cylinder Head Sensor will cut power if it detects over temperature. This will happen before the engine temperature gauge moves up and there are no fault codes.
When it happened to me I was able to drive from Scotland on the motorway at a steady 70(ish) because the engine was being almost air cooled. Off the motorway stop start driving lead to power loss.
Turned out that I had a very small radiator leak and that topping the water up solved the problem short term.
All very puzzling at the time as I was convinced that I'd filled up with some dirty diesel in the far north and the intermittent power loss was the result.
Maybe that will help Thumbs Up
Post #678687 15th Jan 2018 1:48pm
biffabacon67
Managed to get it plugged in, showed up a MAF fault and Turbo boost fault. Fingers crossed the former is causing the later. Tomorrow will tell.
Post #678717 15th Jan 2018 5:48pm
BenB8man
How did you get on?
Post #678951 16th Jan 2018 5:25pm
biffabacon67
MAF Sensor failure!!
Replaced and all sorted, back to normal. So treated the truck to a new set of discs and pads.
So far in 8 years of ownership and 75000 miles, other than routine servicing, I have had to replace the clutch, EGR valve and now the MAF sensor. Not too bad, and all common TDCI faults. I'm well chuffed!!
Cheers for the pointers Ben
Post #678979 16th Jan 2018 7:42pm
BenB8man
You're welcome. Sometimes I surprise even myself Smile
Post #679094 17th Jan 2018 12:03am
biffabacon67
Thumbs Up
Post #679132 17th Jan 2018 7:44am
biffabacon67
Well, latest update is, nothing so far seems to have worked.
It is fine driving around local country roads up and down hills, but hit a dual carrigeway/motorway and do 70-ish miles per hour for 10 miles or so and it goes into limp mode. NO lights on the dash. Turn off the engine and re-start and it resets itself. back to normal.
MAF sensor and MAP sensors both replaced with genuine parts. EGR valve replaced in the last 18 months. intercooler pipe replaced as split.
Shows fault codes
P0234 Turbo/supercharger overboost condition
P1103 Mass Air Flow Sensor in range but higher than expected
Any ideas more than welcome.
Steve
Post #688418 23rd Feb 2018 1:17pm
agentmulder
Kuwait
16th Jan you indicated that it was the MAF, so how long did it work for?
I never wrote down the fault codes, but what you have there triggers memory of the fault descriptions I got when my MAF connector wasn't working, I think pin1 or pin4 wasn't connected. Quite simple to push back in to place, have you had a look at that? Or tried the full disconnect and drive to see if that helps again?
The ECU is better suited to deal with the default (disconnected) values than spurious ones from connections that may not be fully seated once it warms up. Solved the bowel problem, working on the consonants...
Post #688543 23rd Feb 2018 10:50pm
biffabacon67
It "seemed" to last for a couple of hundred miles, but on reflection that was just because i was driving locally on single carriageway roads. So it probably wasn't fixed at all. The MAF connector is one more thing to look at.
Post #688564 24th Feb 2018 8:29am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Hi fellow problem owner
Just had the same problem. Or i should say have had.
Worth checking the harnas to the turbo. Mine failes also
Then read the diagnostics whilst driving! It could be a temp problem which never shows on the gauge!!!!! And i mean never
Then Check turbo. And that’s the costly one
In the end i got it sorted but
Made the modification to the wire harness
Got the allisport radiator
And got a new turbo
Good luck a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #688569 24th Feb 2018 9:37am
