Home > Puma (Tdci) > Heat related power loss, any ideas?
Page 2 of 2 <12
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Re: Heat related power loss, any ideas?
biffabacon67 wrote:
Right guys, as stated above i have a 2010 110 with 75000 on the clock. Its absolutely fine and normal just driving around the doors. Loads of power and acceleration. But, if i attempt to drive 8-10 miles the power and feel seems to tail off and disappear, by 12 miles it couldn't pull the skin off a rice pudding. But let it cool down and its back to normal.
Check out my thread here:
http://www.defender2.net/forum/topic56815.html
It seems that you are describing exactly the same problem. Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #689184 27th Feb 2018 1:31am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Thnx Bergos.
Allthough my problems seem to have disappeared the next time i’am in the workshop i Will Check the headgasket.
Greetings Jacco
Oh Ps. I forgot to mention in my previous post i also did the Nakatanenga SpaceR and the pel switch
Nothing solved the problem on its own but all the little steps solved the problem a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #689194 27th Feb 2018 7:23am
biffabacon67
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Still having issues Evil or Very Mad
Map sensor replaced
Maf sensor replaced
Intrcooler hose replaced
EGR valve replaced
Start up and it goes great. Great around the doors 20-30 miles. Flies on the flat and down hill but add in a slope on a motorway/dual carriageway in top and it dies drops to 50 and then struggles afterwards (limp mode) unless you stop and restart it to reset it. Then it’s back to normal until you labour the engine in top. If I never went anywhere near a dual carriageway/ motorways I would not know anything is wrong.
Post #694745 19th Mar 2018 8:15pm
Bergos
Are you monitoring the temperature with Nanocom, Ultragauge or similar?
Monitoring the engine will give you the information which parameters are out of range and if there are any errors stored in the ECU.
If it is not the overheating problem, then maybe it is overboost. Although I have a Puma by myself I have little experience with this engine. In a Td5, with the symptoms you describe I would guess it is overboost.
Anyway - computer monitoring and recording is a must to solve this. Bergos
Post #694764 19th Mar 2018 9:06pm
Tdi4
I second that. You really need real-time monitoring. You can’t trust the gauges.
My real-time water temp was > 110 degrees and gauge was in the middle. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #694776 19th Mar 2018 9:40pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I hope you find the issue as my van does the same thing.
It's a vauxhaul vivaro , but what you're descriibing is identical to what i get
Post #694797 19th Mar 2018 10:52pm
biffabacon67
Well, after much head scratching and money spent it finally appears to be fixed. Failed turbo actuator!! The actuator was not working fully correctly. Cure was a new turbo. All working correctly now.
Post #705951 8th May 2018 7:41am
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
An expensive solution though Shocked
Post #705964 8th May 2018 9:13am
biffabacon67
£912.00 for a recon exchange turbo fitted with a lifetime warranty. Expensive, but peace of mind for the future!
Post #706057 8th May 2018 5:17pm
Page 2 of 2 <12
