Home > Td5 > Fitting OEM Anti Roll Bars Front & Rear
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Does anybody have an idiot guide on how to fit these please?
Nothing on the old girl at the moment as never fitted
Failed on the Google search
Post #678718 15th Jan 2018 5:59pm
geobloke
As a start http://www.paddockspares.com/downloads/STC8156AAPY_vr1.pdf
It is an easy task that can be done with minimal tools. Biggest hints I can give you is;
    when you come to do this is to park on very level ground
    and when you come to tighten up the chassis mounting bolts you should do up each side incrementally (ie. not one side to torque then the other)
    Grease everything
    take your time
Poly Kit http://www.paddockspares.com/stc8156aapy-a...ushes.html
Rubber Kit http://www.paddockspares.com/stc8156aa-ant...ushes.html
Post #678731 15th Jan 2018 6:29pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
All mounting holes are there you just need the brackets front and rear and roll bars
Tip
Make sure you clean front axle mounts inside the holes or drop links won’t go through
Did it on my td5 and made a world of difference about an hours job each end 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #678732 15th Jan 2018 6:30pm
geobloke
Good tip. I had forgotten that the axle mounts needed de-burring a bit before the ball joint would fit properly. Nothing major just a quick go round with a file.
Post #678734 15th Jan 2018 6:35pm
agentmulder
Kuwait
Yip, pretty basic.
About all I can think of is perhaps image search some examples to reference so you don't install them 'inverted'. Maybe the instructions linked above cover that Thumbs Up Solved the bowel problem, working on the consonants...
Post #678758 15th Jan 2018 7:36pm
rustandoil
A very worthwhile upgrade and not difficult, it should be easy to see what goes where when you have all the parts Thumbs Up
Post #678760 15th Jan 2018 7:47pm
geobloke
My 110 was ARB-less too, the difference was superb with them fitted. Have since upgraded the rear to the X-eng Deflex ARB which is the next level up and i love that it can be disengaged. Wish the front could be too.
FYI those with a roll cage, the Defelx is a GREAT addition... should be high up on the list of mods, especially if you have a roof rack and drawer system in the back...
...AgentMulder... Rolling Eyes
Post #678815 15th Jan 2018 9:40pm
agentmulder
Kuwait
^ ha ha
Oh dear, did my shopping list just get even loooonger? Solved the bowel problem, working on the consonants...
Post #678849 16th Jan 2018 3:51am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
One bit of advice if fitting the Britpart kit, the brackets in the kit that mount the rear ARB and bush to the chassis are for pre Td5 90's you will have to order 2 of the correct mounts and bushes.
I know as I fitted a kit to my sister's 90 and had to order them, other than that a good quality kit.
This does not effect 110's
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #678897 16th Jan 2018 12:47pm
lightning
I fitted the Britpart kit to my 110 TD5 and the rear ARB was a poor fit, it touched the fuel tank cover plate.
I bought an OE rear ARB and that fitted fine.
Post #678991 16th Jan 2018 8:04pm
simon67
Ordered all the parts to fit the ARBs front and rear direct from Land Rover and it came in at £350 not including ARBs
Have I been fiddled here?
Post #679607 18th Jan 2018 12:53pm
pj2106
I brought all mine from eBay ncluding drop links for less than £100 and brought set of take off arb’s for £100
So I think you paid a bit over the odds 2008 110 2.4 XS Utility (Hagrid)
Post #679615 18th Jan 2018 1:47pm
pj2106
Post #679616 18th Jan 2018 1:49pm
rustandoil
£350 does sound a bit steep!...But that genuine part prices I suppose Shocked
Post #679628 18th Jan 2018 2:38pm
Mountain_man
Wales
I swapped the anti-roll bars directly over from a Discovery 1 I was breaking. Fitted no issue. Cheap way of doing it??
Post #679666 18th Jan 2018 5:35pm
