Home > Puma (Tdci) > Integrated key & remote - does anyone make one ? |
Kez Member Since: 11 Apr 2011 Location: UK Posts: 271 |
One thing I really don't like is the 1970 Leyland key and separate fob - so was wondering if anyone made an all in one key that could accept the internal of the existing fob, or failing that a straight replacement?
18th Apr 2011 10:36am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
I've never seen one Kez 2.4 90 XS
18th Apr 2011 11:07am |
Askde the same question to a company called remote key, this was the reply I got:
We have just made a prototype and it is being tested, it will not be out till the summer, keep an eye on the website I have attached a picture of the key, it uses a Renault commercial key head which is very robust we have put a defender key blade in, nothing exciting but it will be better than the 18 year old design you have at the moment, it will require programming with specialist equipment, but the next thing we are working on is we will supply it with a self programming plug, all this is prototype, but hopefully we will have it on sale later this year. Thank you Ian Jameson Remote key Ltd www.remotekey.co.uk <http> I would add I am not associated with the company nor have I ever used them, but if they get the cost right I for one will be buying one! |
18th Apr 2011 2:43pm |
FULLY INTERESTED!!!!!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
18th Apr 2011 2:48pm |
Carjacking, in a civilised country such as Britain, surly not.
Ahhh, sorry, just spotted the flag on your profile |
18th Apr 2011 4:48pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Have you got the later key - not the eariler Layland key...the later key has the land rover oval on it Mike
18th Apr 2011 5:24pm |
Its a 2007 and looks like the old cheepo mini key from back them
18th Apr 2011 5:29pm |
Yes they changed that on a late 57 and 08
Look for a post from me in about mid/late 08 Mike |
18th Apr 2011 8:07pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
We've got the British Leyland key & fob and fiercely proud of it
18th Apr 2011 8:09pm |
MSE - are they interchangeable - could you lost a pic or link of what they now look like?
19th Apr 2011 6:00am |
we've got the Allegro key just looking for a Quartic steering wheel to match and a Leyland Super Care sticker 2.4 90 XS
19th Apr 2011 7:12am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6102 |
You would have thought that it would/might be possible to do something with the disco2 key, as that's integrated and uses the 10AS alarm the same as defenders.
i think the steering lock is totally different though isn't it? wonder if the barrels can be interchanged? |
19th Apr 2011 7:15am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17458 |
The lock barrel probably isn't an issue, since the Disco2 key can be rebladed. The induction coil on the column might be an issue, but again I imagine that they work in a similar way and so can probably be made to work.
An interesting idea, but if it was that simple why hasn't Land-Rover done it already? |
19th Apr 2011 8:42am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
I just got a Ford something-or-other econobox as a courtesy car from the dealer, and it has a very slim integrated remote/key.
Just checked... it is a Fusion. If Ford can do it for an awful little car like the Fusion, why can't LR do it? |
19th Apr 2011 11:56am |
