Home > Puma (Tdci) > Integrated key & remote - does anyone make one ?
Page 3 of 5 <12345>
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
put me down for one Thumbs Up
Post #68720 26th Apr 2011 8:39pm
yawlboy
Ireland 1993 Defender 110 200 Tdi CSW Cairns Blue
and me 1993 110 200tdi Utility in Marine Blue
Gone - various FFRR, D3's, Discos and a Freelander or two.
Post #68721 26th Apr 2011 8:45pm
xatzhs
Yeh as long as it's got a better range than the current one... which seems to be about 2m!
Post #68732 26th Apr 2011 10:18pm
Kez
Isle Of Man
I'll have one too
Post #68735 27th Apr 2011 5:21am
mse
Thats not the fob, thats the unit - do a searcn on how to extend the range (look for AndrewS) Mike
Post #68748 27th Apr 2011 7:20am
pannawonica
Australia
Key
Looks like a real improvement!
Post #68757 27th Apr 2011 9:07am
Alive Tuning
diesel_jim wrote:
You would have thought that it would/might be possible to do something with the disco2 key, as that's integrated and uses the 10AS alarm the same as defenders.
i think the steering lock is totally different though isn't it? wonder if the barrels can be interchanged?
The keys/blades are compatible, but the electronics in the fob are completely different. The Defender 10AS unit is made by Lucas (!), and the Disco 2 BCU is made by Valeo. The coding of the keys is totally different, so this is a non starter. Sad
I do away with the 10AS fobs anyhow, and replace them with clifford fobs. Much smaller, but still seperate.
Post #68758 27th Apr 2011 9:17am
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Or alternatively, and this actually works, simply touch the fob to your head and it works from up to 30' away. Ideal in the pouring rain when you forget to lock it but are already inside drying off! 2001 TD5 110 DCPU in Bonatti Grey
Post #68760 27th Apr 2011 9:26am
dgardel
Italy
Re: remote key prototype photo
ickle wrote:
First picture I've posted - hope it works! Whistle
3 for me (2 keys for everday and one like spare) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #68773 27th Apr 2011 12:23pm
daviec1
aye, suppose if these actually work (i.e. can be programmed from the Nanocom) then I'll take a couple. How much are we talking about? 2001 TD5 110 DCPU in Bonatti Grey
Post #68782 27th Apr 2011 12:44pm
I was sceptical about this for years, but it really does make a difference! Does anyone know why or how the human head has this effect, and what does using it in this way do to the contents?
Post #68795 27th Apr 2011 2:15pm
110
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
In my case it could only improve Very Happy 110 Black Java Puma Utility, Kenlowe fan, bullbar, sides step, tinted windows, bluetoth, Scanguage, BAS,
Post #68803 27th Apr 2011 3:10pm
Grockle
big headed peoples open from 500 metres Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #68809 27th Apr 2011 4:03pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Doesn't the head somehow act as a signal amplifier????... never tried pointing it on other parts of the body to see if it has the same effect ........ but I think I've found a new game for tomorrow morning Mr. Green Mr. Green
As to what effect it has..... hev\zhcf\vc zjjjjjhjjhjhjjj ..... none that I've noticed. Jon - 110 td5 [sold]. Currently Defenderless.
Post #68820 27th Apr 2011 5:49pm
mse
Yes but if you modify it and use your head you get even further range...you head only takes you so far. Mike
Post #68867 27th Apr 2011 10:07pm
Page 3 of 5 <12345>
