Home > Puma (Tdci) > Bonnet hinges rusting on bulkhead!
Zagato
Having looked at about 8, 60 plate low mileage SW's at two dealerships which all had the first signs of rusting of the bonnet hinges where they meet the bulkhead I wondered if anybody had taken this up under warranty. Not so worrying but amazingly they all also had rust stains from the rear capping's in exactly the same spot. This I can sort and will galvanise my capping's but the bulkhead to bonnet hinges are more difficult to resolve as the fixing points would appear to need drilling out, the metal on both sides treating then replaced but I am not sure how you can easily replace them without access to the rear of the bulkhead as it is blocked by the dash.
Claiming under warranty will be a waste of time as usual as they would just rub it down and spray over it but the corrosion is between the two surfaces and needs sorting properly.
Mine also has these rust stains with 106 miles on the clock Rolling Eyes
Post #67764 18th Apr 2011 10:47am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I'm going in today to see the body shop about a new bulkhead i'll let you know what they say.....L/R Have agreed the work Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #67766 18th Apr 2011 10:52am
Grockle
insist it goes to a coachworks and gets done properly,speak to LR customer services 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #67767 18th Apr 2011 10:54am
