Home > Technical > CTEK charger question
dunc
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
I have been using a CTEK MXS 5.0 charger on my 2016 Defender when I'm not able to use. It wouldn't start today, the alarm triggered, didn't turn over etc. The battery is flat and the recovery guy reckons these chargers don't work as well when connected via the cigarette lighter (which mine is). Apparently it is better to connect direct to the battery with crocodile clips.
I don't recall reading about this before on the forum. Has anyone else encountered this - a charger not working correctly/fully when connected via the cigarette lighter? My battery has now been replaced by the recovery chap, I do not want the new one to go the same way as the last.
Post #677148 9th Jan 2018 10:45am
ericvv
As far as I know the cigarette lighter is no permanent live. So not connected when key is not in the contact and in the “on” position.
Just install a 12S plug, buy one of Martin’s adaptors and you are good to go.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #677152 9th Jan 2018 11:05am
leeds
I am not convinced that all 12 volt sockets are permanently live so that may well be an issue.
A 2016 battery needs replacing because it has gone flat? My gut feeling is that the battery needed a good charge maybe on a reconditioning charger. Would a battery less then 2 years old have its plates sulphated up badly? Would the plates be buckled so causing an internal short circuit? I have my doubts about the need to replace the battery rather then give the old one a good charge.
If you invest in a cTek comfort connector such asthis would be a good investment.
HTH
Brendan
Post #677154 9th Jan 2018 11:07am
Swine&Small
Hi. I have been using the "cigarette lighter" on my Defender 90 for 18 months and for 5 years on my VW T5 Camper. Neither have given me any problems, both have been laid up for 4/5 months at a time occasionally and started straight away.
I use a CTEK 7 on both , but would suggest that your problem was either a bad connection in the "lighter", a dodgy battery, or a faulty charger. Question 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #677155 9th Jan 2018 11:10am
ericvv
Made a quick test. My cigarette lighter is only live when the key is inserted in the contact and turned to the second "on" position. Pretty sure 99% of all cars are wired like that, guess all Pumas standard ex Solihull too.
Post #677159 9th Jan 2018 11:29am
Swine&Small
Just did a quick test on mine and the lighter is live when the ignition is off. Maybe the previous owner had it rewired during his 6 months ownership. He appeared to been one of those owners who spends a fortune on the vehicle and never actually used it.
Never thought to check before as it always worked on mine.Sorry to mislead. 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #677169 9th Jan 2018 11:50am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Mine’s off as well, but I just have one installed which is always live. This way I can choose to charge batteries when not at home and charge the car battery itself when I am.
Post #677170 9th Jan 2018 12:05pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
I think you lucked out Swine because as per my Ctek thread, mine is also only live when the key is in the second position! Thumbs Up
Post #677172 9th Jan 2018 12:17pm
Swine&Small
Just thought, I have to turn my lighter plug connected Satnav off manually or it stays on all the time after the key is removed so it must be a live one Thumbs Up 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #677180 9th Jan 2018 12:33pm
The lighter on my 2007 2.4 is only live with the key turned, and it was my understanding that all Pumas (as well as most earlier models) left the factory like this.
It would certainly explain the OP's flat battery!
Post #677183 9th Jan 2018 12:43pm
miker
My 1999TD5 standard lighter socket is only live with ignition on too. It's pretty standard behaviour.
All the ones I've fitted are permanent live however!
Post #677184 9th Jan 2018 12:46pm
dunc
Well thanks boys for clearing that up - doh!
I have used battery savers/chargers for many years on many different vehicles, all via the cigarette lighter, without problem.
Should have known the Defender would be different.
Post #677199 9th Jan 2018 1:56pm
discomog
I use a Ctek charger and charge it via the 13 pin tow socket connected through pins 9 and 13. If your on a 7 pin tow socket you'll need to install a 12S socket and connect through pins 4 and 3.
Martin, site sponsor has made up connectors for both 12S and 13 pin Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #677214 9th Jan 2018 3:20pm
Martin
Site Admin
Site owner Whistle
http://www.defender2.net/shop/tow-electric...c-p45.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #677222 9th Jan 2018 4:09pm
Mr Fox
Would have been the perfect solution if I didn't have the 7 pin 12N Sad
Post #677241 9th Jan 2018 5:19pm
