Home > For Sale & Wanted > WANTED P38 BITS |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Yes i know this is the Defender forum but there isn,t a P38 one and i know lots of you might have stuff lurking in your garage
WANTED Diesil Battery Alternator Regulator/Diode Pack Diesil Clutch Assy Wheel Bearings Drivers Door handle and door lock assy If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
17th Apr 2011 12:20pm |
That sounds like the person i need to speak to, please send me over his no when you are next in your office many thanks.
Lewis If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
17th Apr 2011 8:06pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Hi Lewis
This lot http://rangeroverbreakers.com/ Only a small lock up, near Timsbury JST had a autobox off them,, ( as a donor for Ashcroft, so no idea what it was like) but they seamed helpful enough !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
18th Apr 2011 8:23am |
Thanks for the web link, the P38 auto box makes a good 6 spd semi auto box with electric shift racers use them a lot, the 4 speeds are turned into 6 using clever torque converter lock up If everything is under control you are not going fast enough.
18th Apr 2011 8:10pm |
Just put the post code in Google maps and had a look where it is and result I have got a job nearby in Midsomer Norton and my misses will be over the moon if i want to go up there as it is near the Bookbarn at Hallatraw, she can get lost in there for hours as no doubt i could in a Range Rover scrapyard (heaven) If everything is under control you are not going fast enough.
18th Apr 2011 8:25pm |
