Home > For Sale & Wanted > WANTED P38 BITS
noworries4x4
WANTED P38 BITS
Yes i know this is the Defender forum but there isn,t a P38 one and i know lots of you might have stuff lurking in your garage
WANTED
Diesil Battery
Alternator Regulator/Diode Pack
Diesil Clutch Assy
Wheel Bearings
Drivers Door handle and door lock assy If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #67659 17th Apr 2011 12:20pm
TJ101
Hi, There is a bloke up near Bristol/Bath area, that breaks P38,s,, have his card in the office !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #67684 17th Apr 2011 5:40pm
noworries4x4
That sounds like the person i need to speak to, please send me over his no when you are next in your office many thanks.
Lewis If everything is under control you are not going fast enough.
No Worries 4X4
Post #67702 17th Apr 2011 8:06pm
TJ101
Hi Lewis
This lot http://rangeroverbreakers.com/
Only a small lock up, near Timsbury
JST had a autobox off them,, ( as a donor for Ashcroft, so no idea what it was like) but they seamed helpful enough !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #67737 18th Apr 2011 8:23am
noworries4x4
Thanks for the web link, the P38 auto box makes a good 6 spd semi auto box with electric shift racers use them a lot, the 4 speeds are turned into 6 using clever torque converter lock up If everything is under control you are not going fast enough.
No Worries 4X4
Post #67863 18th Apr 2011 8:10pm
noworries4x4
Just put the post code in Google maps and had a look where it is and result I have got a job nearby in Midsomer Norton and my misses will be over the moon if i want to go up there as it is near the Bookbarn at Hallatraw, she can get lost in there for hours as no doubt i could in a Range Rover scrapyard (heaven) Very Happy If everything is under control you are not going fast enough.
No Worries 4X4
Post #67871 18th Apr 2011 8:25pm
