Home > Maintenance & Modifications > Double speed indicator |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
Could be corrosion in the bulb holder or a connection issue, probably rear indicator? 2002 90 Td5 Station Wagon
6th Jan 2018 9:42pm |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Thanks, will give it a good clean tomo.
6th Jan 2018 9:43pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
I think it's normal for indicators to flash double speed if a bulb fails etc. - or it used to be.
As indicated by Grafty, if the bulb is tested and known as good, I'd give the connections a really good clean and get a multi meter or similar on the wiring. Sometimes the connection in the bulb holder needs a bit of 'adjustment.' Sometimes bulbs (or 'lamps' as I am continually reminded) can fail at the base and show no visible signs at the element. Worth having a few spares anyway, or better still, get some LED's as they are only cheap for a pair of complete 'original' looking lights - RDX, Wipac on eBay. Hope you get it sorted |
7th Jan 2018 9:10am |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Remember to check the side indicators on the front wings too?
7th Jan 2018 12:54pm |
