Home > Maintenance & Modifications > Double speed indicator
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
I assumed this would be the bulb but I removed the bulb not lighting up and it looked fine. Could this be something else? Thanks for any advice. JJ
Post #676457 6th Jan 2018 8:30pm
grafty99
Could be corrosion in the bulb holder or a connection issue, probably rear indicator? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #676478 6th Jan 2018 9:42pm
Jonno1968
Thanks, will give it a good clean tomo.
Post #676479 6th Jan 2018 9:43pm
Screbble
I think it's normal for indicators to flash double speed if a bulb fails etc. - or it used to be.
As indicated by Grafty, if the bulb is tested and known as good, I'd give the connections a really good clean and get a multi meter or similar on the wiring. Sometimes the connection in the bulb holder needs a bit of 'adjustment.'
Sometimes bulbs (or 'lamps' as I am continually reminded) can fail at the base and show no visible signs at the element.
Worth having a few spares anyway, or better still, get some LED's as they are only cheap for a pair of complete 'original' looking lights - RDX, Wipac on eBay.
Hope you get it sorted Thumbs Up
Post #676549 7th Jan 2018 9:10am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Remember to check the side indicators on the front wings too?
Post #676587 7th Jan 2018 12:54pm
