Home > Maintenance & Modifications > Diesel cabin heaters |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
Have a look at the Planar heater on 4x4overlander/Nakatanenga website.
Brendan |
11th Dec 2017 7:10pm |
A post from a few days ago.
http://www.defender2.net/forum/topic58275.html |
11th Dec 2017 7:15pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
Hello,
I have put mine inside my mss cubby box, holes drilled below for exhaust and burner inlet. A hole at the rest for hot air out which goes into a manifold to distribute the hot air. I posted some pictures here a while ago. http://www.defender2.net/forum/topic45695.html |
13th Dec 2017 9:06am |
steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 175 |
Fitted mine in passenger seat box so exhaust and intake go through the floor and hot air is pumped out high up in passenger footwell via a directional nozzle.
6th Jan 2018 12:03am |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1576 |
rear wheel arch behind passenger seat.you have a limited length of fuel pipe that the std pump will pull from.
nothing wrong with planar heaters but almost every truck, bus or van that using diesel power heating uses eberspachers or webasto.lots of dealers easy spare parts. |
6th Jan 2018 8:50pm |
