Home > Maintenance & Modifications > Diesel cabin heaters
ibexman
I’m looking at Eberspächer/ webasto heaters can anyone show me their installs in a 90Td5, why did you choose one over the other cheers Chris
Post #670339 11th Dec 2017 5:54pm
leeds
Have a look at the Planar heater on 4x4overlander/Nakatanenga website.
Brendan
Post #670346 11th Dec 2017 6:10pm
zsd-puma
Post #670347 11th Dec 2017 6:15pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello,
I have put mine inside my mss cubby box, holes drilled below for exhaust and burner inlet. A hole at the rest for hot air out which goes into a manifold to distribute the hot air.
I posted some pictures here a while ago.
http://www.defender2.net/forum/topic45695.html
Post #670637 13th Dec 2017 8:06am
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
Fitted mine in passenger seat box so exhaust and intake go through the floor and hot air is pumped out high up in passenger footwell via a directional nozzle.
Post #676241 5th Jan 2018 11:03pm
Mdm
rear wheel arch behind passenger seat.you have a limited length of fuel pipe that the std pump will pull from.
nothing wrong with planar heaters but almost every truck, bus or van that using diesel power heating uses eberspachers or webasto.lots of dealers easy spare parts.
Post #676446 6th Jan 2018 7:50pm
